Need to check timer on dishwasher using ohm setting of x 1000.
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.
Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value.
I hope this helps!
SOURCE: I need a manual for my Gardener Bender Multimeter
Have you tried the GardnerBender.com website?
SOURCE: checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
SOURCE: what do you set the digital multimeter on to test
One end of the device or the circuit must be isolated. You can read contiuity through a separate component.
Lou
SOURCE: how do I set digital
plug black lead into bottom socket. Red lead goes into middle socket.
Select the Ohms range on the dial... the lower left section ... Denoted by a Greek letter Omega (Upside down horseshoe)
set the range on the dial (This meter goes from 200 to 2000K ohms)
and read away....
The
soap trap and its cap covers the soap in your dishwasher after you fill
it and then swings open to dispense the soap when the wash cycle
starts. If your dishes aren't getting clean or you notice the soap trap
door is still shut after the dishwasher finishes a load, it may
indicate a problem with the soap trap you'll need to fix.
Instructions Things You'll Need:
