Question about Samsung Yepp YH-J70 Digital Media Player
MTP supported on only XP PC with WMP10
I just bought a samsung yh-j70 and when i connect it to the usb ports on my computer it just says "MTP supported on only XP PC with WMP10" then it just goes off, so i thinking it must only work on xp with window media player 10 so i took round to my mates house because he has both XP and WMP10 and it still said the same message!!!! what is happening!!! please tell me so i can fix this probelm and actully put music on it.
Solution #2 works fine! Thanks!
Posted on Nov 09, 2008
    Problem Solver:
  • 5 Answers
I had the same problem and I saw this fix somewhere. I use it and it works fine: plug usb cable into computer (don't attach usb cable to the player yet), turn player on, move 'hold'button to 'hold' position, Press and hold 'record' button while you plug the usb cable into the player. the screen will show a message that the player is connected via usb, no more useless mtp.
Posted on Apr 23, 2008
You know what man, i hav tha same problem and i fixed it!!! allu need to do is reboot ur pc install wmp10 off the cd and restart it and it will work!!
Posted on Feb 08, 2007
Software for adding to my player some music and films
I don't know if there's a software available right now, but that's not a shoe stopper.You can still be able to copy musics or any other file from/to your player to/from a Computer using it as an external drive; for that you have to chenge the settings from Charge to removable disk on menu/settings/system/PC connect mode.
Dec 04, 2008 | Samsung Yepp YH-J70 Digital Media Player
Lost cahrger of my Player
If you have a dealer close to you that's your solution, a part from that you can either just surf on the web,in any searching engine or change the settings on your player to use your USB port to computer for charging instead as an external drive.For the last suggestion follow these easy steps:
1.Press menu on Player
2.Select Settings
3. Under settings shown choose System
4.Pc Connect mode
5.Click on Charge
For more detail see your manufacturer booklet
Dec 02, 2008 | Samsung Yepp YH-J70 Digital Media Player
Lost Installation CD for YH-J70
Yes, Samsung has all the software and drivers available.
http://www.samsung.com/us/support/
Oct 03, 2008 | Samsung Yepp YH-J70 Digital Media Player
Samsung YH-J70
I had the same problem - the hard drive had failed, which is a common fault. I bought a new one on eBay - a Toshiba MK3006GAL 30GB - which worked fine.
BUT... the drive came completely unformatted and I had to format it on a laptop first as I could not get it to format in the YH-J70. If the drive is FAT32 format, however, you should be OK to just put it in the YH-J70 and format it with Samsung Media Studio.
Sep 19, 2008 | Samsung YH-925 MP3 Player
Samsung digittal audio player yh-j70
All the drivers and software are still available for download on Samsung's website.
Sep 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
MTP Connected but not Accessible
It is simple. Forget the MTP Mode. Simply put the player on, put it on hold, press and hold the record button while you plug in the cord. It will go into USB mode, the only thing is that you have to do that everytime. Hope this works.
Jun 30, 2008 | Samsung Yepp YH-J70 Digital Media Player
How do you update firmware on YEPP YH-J70?
unzip file, put it directly on disc don't use any program, disconnect, turn off, put on recharge and power on the player.
Dec 09, 2007 | Samsung Yepp YH-J70 Digital Media Player
Cannot charge my yh-j70
When I first got my yh j70 I had the same problem. Have you made sure its in 'charge' mode? When you go to 'settings' there is an option tha allows you to switch from 'charge' mode to USB connect mode. You have to switch it depending on what you are trying to do. Hope this helps.
Sep 16, 2007 | Samsung Yepp YH-J70 Digital Media Player
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
Samsung Yepp YH-J70 Digital Media Player Logo
89 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
