Question about Samsung DVD-VR357
I have a Samsung DVD -VR 357 combo unit and i can't record
When i attempt to record any TV programs via VHS or DVD i get a message on my TV that says Cannot Record Copy Protected Movie. I tried re-setting the unit and it did nothing.
  • 4 more comments
  • Christopher Reilly
    Christopher Reilly Nov 21, 2008
  • jbier Dec 09, 2008
    In addition to not being able to record any tv programs because of the Cannot Record Copy Protected movie I also get a message: Cannot record copy-protected tapes when I'm trying to copy a VHS tape to DVD.
  • kjsnight Dec 20, 2008
    Yes, I have the same problem. The unit was fine for a couple of months but now I try to record a broadcast or cable channel onto videocassette or DVD and get the same message.
    When the problem first started, I could reboot the unit and cable (Optimum) and it would work, but only if I continued recording on the same disk. That quick fix no longer works either.
  • krmitbug Dec 21, 2008
    I have the same exact problem...reboot no longer corrects the issue
  • Jordash40 Jan 03, 2009
    I am having the same problem. It won't reset.
  • theshyone702 Jan 10, 2009
    I have the same problem, can't record copyrighted movie, but it is just a tv broadcast, soap opera and a weekly nbc show, neither works...and the one time it did work the audio track didn't match the video track. I'm currently using dvd-r discs...any suggestions? Oh, and I couldn't find the update firmware section on samsung.com.
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Posted on Jan 10, 2009
It seems that if you disconnect the input video from your provider.... the unit will then transfer VHS to DVD...very odd
Posted on Dec 21, 2008
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Samsung dvd vr-357; recorded DVD only plays on the player
You have to "Finalize" the disc before it will play on other units. Go to Disc Menu, Second choice listed(not in front of it right now) Selections to right will offer disc Finalize. Say YES.
Jul 19, 2009 | Samsung DVD-VR357
Samsung dvd-vr 357 remote code for comcast
The HD cable remote --> Code 21075
May 16, 2008 | Televison & Video
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
Backup my vhs tapes
First hook up the VR357 to the TV with any cable ..
Then put a VCR tape into the VHS player.. get the tape to where you want to start the recording and press stop.
Then put a blank DVD in (-r or -rw is the best)
Then press VCR on the remote
Then press TO DVD on remote
you will see the word COPY come up on the DVD player and the VHS tape will start to play.
When you are done just press stop twice. and you will get a message that says "updating information to disk"
Dec 15, 2007 | Samsung DVD-VR357
Copying vhs to dvd using samsung vr357 ??
I do not think you would have to worry about a way to disable the copy protection that is on the vhs tapes. you are not going to record over them. You are just going to transfer information to the dvd side. jh
Nov 18, 2007 | Samsung DVD-VR357
Samsung DVD-VR357 Logo
1,202 people viewed this question
Jerry Greenberg
Jerry Greenberg
