Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
Power button broke
The camera will not turn n with either a fully charged battery or with the power cord.
  • thusia3mp Feb 13, 2009
    1. there was an indication signal that the head was very dirty.Thern ythe camera shut down , no full charge battery nor power cord when used was able to power up the camera.
    2. thank you.
    Champion:
  • 221 Answers
Definitely a power supply problem. the power supply board is about $200 plus labor.
Posted on Nov 24, 2008
  • Panasonic Master
  • 2,794 Answers
Sounds like the power supply has a problem. You could take it into a camera shop and see what your options are.
Posted on Nov 15, 2008
My sl102 samsung wont turn on
Are you sure the battery is correctly charged?
Most USB connectors on most PC's don't deliver enough power to charge the battery. Try to charge the battery with the power cord till the green LED is on.
If you'r sure the battery is fully charged and the same happens again, remove the battery for a small time and put it in again.
Feb 20, 2013 | Samsung SL102 Digital Camera
The camera will not turn on, batt r charged. Internal batt is good
How do you know that batteries are fully charged? If it won't power up then the indicator won't tell you their level. Pull both batteries. Push the power button (using what minimal power is left anywhere in the system.) Plug the camera into the external power source (mine has a base that will charge your battery, and supplies a cord for power to the camera.). If it still doesn't power up with the external power source, then I would say there's something wrong, but I'm betting it's the battery/batteries.
Jan 29, 2013 | Cameras
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
