Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
SIR-S4040R will no longer power up (except the fan)
I unpluged my DVR and when I plugged it back in, all that happened was the fan began to run.
I cannot get the system to do anything other than that. Any suggestions would be appreciated.
Thank you for your time and have a great day!!
  • Anonymous May 17, 2009
    This has happened to my unit as well. While I was looking online, it just started up with my assistance. Now it has happened again... I probably wont be replacing it.
  • 149 Answers
Hold in the power button for at least 10 seconds. It should reboot. If not the DVR needs to be replaced.
Posted on Nov 13, 2008
Find remaining recording space on SAMSUNG SIR-S4040R
You will have to "Find space" by deleting something/anything to make "space" for "New" material. Basically it is trying to tell you the drive is filled up and ya need to either delete or cut & paste away to some other media, some data, to get more space to record more stuff. OK?
Jan 27, 2010 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Jan 16, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Power Issue?
unplug the satellite cables and restart the dvr. if the dvr powers up plug in the cables when u see searching for satellite.
Oct 11, 2008 | Directv HR10-250 DTV Receiver
DVR S4040R Tivo box
Your hard drive may have crashed. Can you hear any disk activity when you plug in the unit? The hard drive can be replaced, but probably better to either just get a replacement unit (you can get them on eBay for $40 or less) or upgrade to a newer receiver.
Jul 15, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
My SIR-S4040R no longer turns on..
If the unit doesn't power on at all, no fan spinning and no power light, then it's either your power supply, and/or motherboard. Your hard drive could be damaged as well. You can find power supplies by googling tivo power supplies.
You may be better off sending out the unit for testing/repair. I recommend CCS in Indiana. Fast, and friendly service, used them many times. You will need to lose anything that was on the unit (settings, season passes and recordings) to ensure the drive is fully functional.
Dec 29, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Directv dvr
unplug all the cables except the video out and the power cord. if i loads and stays on after the 14 min. there is a cabling or dish issue. if it turns off the dvr is bad
Nov 29, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Oct 21, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
447 people viewed this question
Henry  Thomas
Henry Thomas
