Question about Adtran NetVanta 3200 Router
Adtran Netvanta 3200 to Kentrox DataSmart 658 CSU to fractional T
I have a Netvanta 3200 with Serial Network Interface Module (NIM). It connects to a Kentrox Datasmart CSU. The Kentrox is configured so channels 21 - 24 are for data ( 1 in channel config). The Adtran originally had a T1 interface but since the T is split for voice / data with the Kentrox we had to replace the T1 NIM with the serial (per Adtran). I configured the PPP interface with the IP address supplied by the ISP then configured PPP to cross-link to the serial interface. I'm new to the Adtran so I'm lost at this point as to why serial 1/1 is up but line protocol is down and PPP is down. Help greatly appreciated.
Here is config with ip edited to prevent hacking attemtps
show runn
Building configuration...
hostname "test"
enable password
clock timezone -5-Eastern-Time
ip subnet-zero
ip classless
ip name-server removed
ip default-gateway x.x.191.153 (edited)
ip routing
event-history on
no logging forwarding
no logging email
logging email priority-level info
username "admin" password ""
ip policy-timeout tcp telnet 14400
ip policy-timeout tcp ssh 60
ip policy-timeout udp snmp 61
ip firewall
no ip firewall alg h323
ip firewall alg sip
ip dhcp-server pool "DHCPPOOL"
network 192.168.0.0 255.255.255.0
dns-server 199.224.86.15 199.224.86.16
netbios-node-type h-node
default-router 192.168.0.1
interface eth 0/1
description edited
ip address x.x.38.161 255.255.255.248
ip address 192.168.247.34 255.255.255.0 secondary
no shutdown
interface ser 1/1
et-clock-source rxclock
no shutdown
interface ppp 1
ip address x.x.191.154 255.255.255.252
ppp multilink
no shutdown
cross-connect 1 ser 1/1 ppp 1
ip access-list standard MatchAll
permit any
ip policy-class Inside
! Implicit discard
ip policy-class Outside
discard list MatchAll
ip route 0.0.0.0 0.0.0.0 x.x.191.153
no ip tftp server
ip http server
ip http secure-server
ip snmp agent
no ip ftp agent
line con 0
login
password
line telnet 0 4
login
password
sntp server time-a.nist.gov version 3
end
5 Suggested Answers
JaxPlanet
  • 922 Answers
SOURCE: Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Posted on Jan 27, 2010
SOURCE: setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock set 23:58:00 05 May 2010
Posted on May 06, 2010
SOURCE: Can you please advise how
Call ADTRAN Technical Support at 1-800-4ADTRAN and they will be happy to assist you.
Posted on Oct 08, 2010
rajendrasngh
  • 393 Answers
SOURCE: How do I factory default
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
Posted on May 19, 2011
I do not know the password to acccess adtran 3430 router. how can I reset the router to reconfigure
Thank you for using FixYa
The default password is 'password' and then 'admin'
uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
Apr 29, 2011 | Adtran Netvanta 3430 Router
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Nov 24, 2010 | Adtran NetVanta 3200 Router
I have an Adtran NetVanta 1335 Router that keeps shutting itself off everynight after my store does all it downloads. I have put it onto it own power supply, any assistance to help keep it up would be...
You need to enter maintenance mode (a web interface) and check the power settings from there as some of these have the ability to sleep etc at preset times.
sort of added security and green all in one function
Aug 31, 2010 | Adtran NetVanta 1335 Router (1700515E2)
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
Oct 20, 2009 | Adtran NetVanta 3200 Router
Setting timezones on Netvanta 3200 router
Aug 28, 2009 | Adtran NetVanta 3200 Router
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
May 25, 2009 | Adtran NetVanta 3200 Router
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Adtran NetVanta 3200 Router Logo
351 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
