Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba Rear Projection TV 42WT29B
When i turn the tv on nothing comes on irrespective of the input selected. sometimes i leave it on for hours and the picture comes up but withing a short time the picture start rolling then i will have to turn it off, if i am lucky i turn it on again and it comes up but again the pictures start rolling even if it does not roll when i change the channel it will not stay long then it will start rolling this is driving mad.... any help will be very much appreciated thanks
    President:
  • 3,130 Answers
This is a problem with the low voltage condition in the main power supply or the sweep supply, or there is bad capacitors in the vertical driver circuit, or the PIP circuit if there is one. the best way to troubleshoot this would be with a schematic, measure all the voltages and see if there are any lower then normal levels. In the vertical and PIP circuits, you will need an ESR type capacitor meter. if you dont own this equipment, or have had no experience working on solid state electronics, play it safe and call in a tech to assist you in this repair. Good Luck Please dont forget to rate this thread.
Posted on Dec 12, 2006
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
May 20, 2012 | Toshiba 50A50 50" Rear Projection...
Tv/video switch won't switch
The model indicated is a older Toshiba rear projection(if another brand/model let me know)
You should be able to select the rear inputs either via the remote (original one) or with the input (video) button on the set.
If in the menu they are grayed out--it means they have been locked out.
Failing that a serious problem exists in the set's microprocessor.
Hint: if you have not tried it UNPLUG THE SET FOR A WHILE TO SEE IF WHEN YOU PLUG IT BACK IT WILL RESET and restore the inputs.
Mar 23, 2012 | Toshiba 42H81 42" Rear Projection...
My ' plastic' screen is damaged, can i replace it? i have a 42WT29B
can go to any used tv shop and have them order a new one or you can order one through the company it comes from
Feb 27, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
Regards
What About Bob
Feb 19, 2008 | Televison & Video
42wt29b toshiba tv
You likely have bad convergecne ouput IC's.  They sometimes will be intermittent untill they fail completely.
Oct 01, 2007 | Toshiba 42H83 42" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
