1995 Nissan Maxima Logo
Anonymous Posted on Sep 30, 2017
I keep getting this code PO443 evap8
I got a new valve assy. solenoid and still get the same code keeps comming back po443. What to do next? The plugs keeps getting alot of carbon on them and when I turn it off it sometimes take a few min. to start back up. I know that the carbon has alot to do with it starting. Help me to fix the problem show me some pictures of what to do to fix this issue.
marlon gonzaga
Level 1:
Habit-Forming:
New Friend:
  • Contributor 28 Answers
  • Posted on Oct 03, 2017
marlon gonzaga
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
28
Questions
Helped
15096
Points
89
P0443,look at the evap control system pressure sensor,or the evap canister purge volume volume solinoid valve[the valve is stock open]hoses,,maybe the hoses are connected incorrectly..
5 Related Answers
Anonymous
  • Posted on Dec 26, 2008
SOURCE: 1997 nissan altima cranks over but dont start sometimes once a we
that could be your starter
Anonymous
  • Posted on Feb 24, 2009
SOURCE: code p 1446 solenoid valve malfunction in sentra 2005
I have the same problem with my 2005 sentra. It is the vent control valve. The only cheap way to fix this would be to take it off and spray wd-40 and see if it works. You could also get the part form a junk yard. Nissanpartsdirect also has it. I beleive it is officially called the vapor canister.
Anonymous
  • 521 Answers
  • Posted on Jul 19, 2009
SOURCE: 2004 xterra P0505 code-idle air control
IAC valve has gone bad. Its located on the throttle body and is what controlls/keeps the vehicle running at idle.
Mustgo
Vincent G
  • 2363 Answers
  • Posted on Dec 19, 2009
SOURCE: i am getting p0400 and p 0402 codes
Check the EGR air passage tube again.
You may miss some on the first pass.
Check for
vacuum leaks on intake manifold,
the air tube between the air filter.
intake manifold vacuum hose.
clean throttle plate with Berryman carburator cleaner
SEE sample picture HERE
Also remove carbon built up behind the EGR valve and the EGR passage tube.
Vacuum leak WILL offset the intended 14.7 to 1 air fuel ratio.
More un-metered air (leaks) will lean out the fuel mixture.
Use small amount of Berryman carb clearer at potential air leak area will help you identify trouble spot.
At idle,just spray and listen for the RPM surge.
The in-rush of carb clearer will increase the RPM on the motor.
Record the problem spot(s) and address it later.
EGR carbon built up require 2+ hours to clean from start to finish.
You will need a new EGR base gasket before your start.
Locate and remove the EGR valve after the vehicle is cool down.
Carefully record the connector and vacuum line (for older vehicle) location by drawing an easily to follow diagram.
Remove the EGR valve.
Inspect the location of the carbon built-up inside the valve and the EGR passage tube.
SOAK these areas with WD-40 spary.
You will need a small screwdriver,cloth hanger and lot of newspaper and time to get this cleaning done right.
RE-SOAK the carbon and let it sit for over-night will also help.
One the last round,pass a shop vacuum of the EGR valve and the passage pipe.
Install the new EGR gasket and connectors.
Allow the vehicle to warm up outdoor to burn up any remaining WD-40.
Take it for a test drive.
Please rate my answer if it's useful to you.
Cheers,
Mustgo
speedwagen
speedwagen
  • 491 Answers
  • Posted on Oct 23, 2010
SOURCE: i have a engine lite on and the code is po443
P0443 code - Evap Purge Valve Solenoid malfunction.
Check to make sure your gas cap is on tight
2answers
Replaced front and fuel tank evap solenoid still getting po443 code on 2011 chevy cruze what is a solution
Try a new gas cap, that is usually the culprit. Around $20 on up for keyed at any part store. And easy to put on.
Does the purge valve keep the engine from starting?
You got the code
You can google the code to learn about it
Type: OBD PO443
The internet will explain the valves function & location,etc
The fact you have a code don't mean the part is bad
It may well be,but the evap system has to be tested & the
valve component tested & fail to need replacement
Nothing to do with starting
It opens to pull fuel tank fumes into the engine & burn them
based on computer strategy
If it is stuck open then you get unmetered air into the motor &
it can effect your fuel trim & cylinder firing
Po443 p0443
The valve is mounted on the engine near the middle of the intake on most models.
Keep in mind the code is for a problem with the circuit which may or may not involve the actual valve. The valve and control would need to be tested.
Wwhat does code po443 mean on nissan maxima 1996
2008 Nissan frontier code po443 what doesit m aen on tell how to fix it how dow I find on the truck thanks
2000 Pontiac Montana PO443 is failing smog
Hi there:
Potential Causes could be the Evaporative Emission (EVAP) Purge Solenoid, fail on Powertrain Control Module (PCM) or damage wiring harness.
In THIS LINK could check additional specific details about this generic code.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
1helpful
How do I fix fault code po443?
P0443 INFINITI - EVAP Canister Purge Volume Control Solenoid Valve
Possible causes- EVAP control system pressure sensor
- Damage harness or connectors to the Purge Control Valve
- The valve circuit is open or shorted
- EVAP canister purge volume control solenoid valve may be faulty (The valve is stuck open)
Tech notes It's a very common problem with Infiniti vehicles. If the harness is not damaged, it's very likely that the problem is the canister purge volume control solenoid valve.
Read more: http://engine-codes.com/p0443_infiniti.html#ixzz1yqKLq8YE
4helpful
I am getting codes PO440 PO443 PO 449 on my 2000 Silverado and the SES light is on
PO440 Possible Causes:
Charcoal canister is loaded with fuel or moisture
Fuel filler cap is loose, cross-threaded, damaged or wrong part
Fuel tank, fuel filler neck or fuel sending unit 'O' ring is leaking
Fuel tank pressure sensor is damaged, disconnected or it failed
Fuel tank vapor line(s) is clogged, damaged or disconnected
Purge valve vapor line is clogged, damaged, or disconnected
Purge or vent solenoid power circuit is open (check the fuse)
PCM has failed
PO443:
Purge solenoid control circuit is open or shorted to ground
Purge solenoid control circuit is shorted to system power (B+)
Purge solenoid power circuit is open (test the ENG1 fuse)
Purge solenoid is damaged or has failed
PCM has failed
PO449:
Sames as PO443.
Hope this helps.
1helpful
2answers
Check engine light on , code po443 1998 sonata
To cause a P0443, there has to be a problem with the purge control CIRCUIT, not necessarily the valve. Usually they are a unit housing the valve and the solenoid as an assembly. Or it could be comprised of a separate solenoid with vacuum lines to a purge valve. That said, it could be any of the following:
  • Bad purge solenoid (internal short or open)
  • Wiring harness chafing or rubbing another component causing short or open on control circuit
  • Connector worn, broken or shorted due to water intrusion
  • Driver circuit inside powertrain control module (PCM) is bad
I would just clear out the code and if it returns then try the above. Hope this helps you a little bit!
Sincerely,
JC
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
