Question about Cannon Office Equipment & Supplies
I have a cannon cannon iPIXMA 4000, and have just changed my computer for an imac but cannot locate my installation disc for it,I have my A560 and A95 CAMERA solution discs and wondered if it`s possible to install it via them? Can you please help? MR B McGrath
  • lizandbri861 Nov 12, 2008
    Thank  god for druids! really sorted my problem .
  • 2,712 Answers
You can download the Mac softwrare from here:
You cannot use the camera software to work with the printer. They require separate drivers.
Should you require any further help, please post back with details. Or else, kindly rate this a Fixya in appreciation for my efforts.
Thank you for using Fixya!
Posted on Nov 12, 2008
How to reset administrator password on imac osx 10.6 pc
  • Insert the Mac OS X installation disc into your computer's optical drive (or an optical drive connected to your computer), and then double-click the Install Mac OS X icon.
  • Note:If you're using another computer's optical drive, make sure your computer is set up for remote installation, and then go to step 3.
  • In the Installer, click Utilities, and then click Restart.
  • When the Language Chooser appears, select your language, and then click the Continue button (looks like an arrow).
  • In the Installer, choose Utilities > Reset Password.
  • Follow the onscreen instructions to change the password.
  • Sep 24, 2013 | Apple iMac 24" Desktop
    I lost my install disc for Canon PowerShot A560 camera
    You don't need to install your camera in order to use it.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
    May 25, 2012 | Canon PowerShot A560 Digital Camera
    How do I set the self timer on my cannon a560 camera?
    Press the self-timer button to cycle through self-timer settings. The rectangle indicates normal shooting, the clock indicates self-timer. Depending on the shooting mode, you may also see overlapped rectangles for continuous shooting.
    To change the delay time, select [Self-timer] from the Recording menu.
    The self-timer button is the same as the down-arrow on the circular multi-selector, marked with a clock.
    Jul 20, 2010 | Canon PowerShot A560 Digital Camera
    A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
    The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
    If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
    ht3007_1.gifFigure 1 Manual eject button
    Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
    Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
    Oct 10, 2009 | Apple iMac G4 Desktop
    A560 cannon camera, I want the date to appear while printing.
    The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
    Jun 29, 2009 | Canon PowerShot A560 Digital Camera
    USB connection with the camera causes computer to crash.
    Try using a different USB cable. The connections between cameras and computers usually are problematic. A card reader will allow you to download the pictures from the SD card, without problems and saving your camera's battery power supply
    May 04, 2009 | Canon PowerShot A560 Digital Camera
    Playing PS2 on apple iMac
    if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
    you could buy an external CD/DVD drive and then use smaller discs with the iMac.
    Jun 10, 2008 | Apple iMac G5 Desktop
    Cannon a560 dital camera
    Click on "Start Menu" (lower left corner of your computer screen). Select "Control Panel", then double click on "Display". When the display control panel opens, click on the "Settings" tab. You can now select and set a Screen Resolution for your computer's monitor of at least 1024 x 768 pixels.
    Feb 07, 2008 | Canon PowerShot A560 Digital Camera
    62 people viewed this question
    Top Cannon Office Equipment & Supplies Experts
    Greg Cann
    Greg Cann
    Iqbal Husain
    Iqbal Husain
    Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
