Question about Sony KP-41T65 41" Rear Projection Television
Tv flickers/blink i have a sony kp 41s4u rear projection tv. when the tv is switched on the television flickers on all channels. the only way we can find to stop this is to turn down the contrast and brightness which then stops the flickering but the picture is really dark, if something prominent in white comes on then it flickers again. can anyone suggest anything please. teresa
  • 1 more comment
  • Kellard1 Feb 17, 2008
    SameModel-tv also flickers - any help?
  • judas Pig Aug 11, 2008
    i have the same problem , has any1 got the answer. What i have found to rectify slightly is switching picture format to 16:9.
    But would like a rectify completly, Help any1
  • whitelegg2 Nov 19, 2008
    sony kp-41s4u blinks when tv is bright not when dark
    Top Expert:
  • Sony Master
  • 12,962 Answers
Given the vintage of set it might be hard to even get parts for it. And being a Sony, it is traditionally very expensive to repair and not really cost effective. Best bet is to give set a decent burial and shop for a new set.
Posted on Sep 19, 2017
SOURCE: rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
Posted on Jan 14, 2007
SOURCE: Sony Rear Projection KP-41S4U
change the rgb ic thats the stk ic
Posted on Nov 07, 2007
  • 51 Answers
SOURCE: Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
Posted on Mar 08, 2008
  • 116 Answers
SOURCE: Sony KP-51WS510 51 in. Dark Picture
These sets have been known to have loose welds in the picture tubes. Most likely your tubes are showing this problem.
Posted on Apr 17, 2008
  • 320 Answers
SOURCE: flickering
Have you replaced the lamp? That's the first thing I would try.
Posted on Oct 19, 2008
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
Sony KP-57WS500 Rear Projection TV Problem
hello if you could tell me how many times it blinks i'll try and tell you the fault thanks
Oct 25, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a sony kp-57wv600 57 inch tv. and the channel button does not work. The channel button on the tv and the remote does not work. When I hit the channel button all that happens is the tv flickers but...
The first thing to do is to rescan for channels. If for some reason the channel memory got wiped out, there could be no other "available" channels to change to. The "flicker" you see is the TV changing to the same channel. Try the rescan and update this if that does not resolve the problem. Let's eliminate the simple stuff first. If the rescan DOES resolve the problem, please update this with that information as well and we will try to find out what cleared out the channel memory.
Aug 08, 2009 | Sony KP-57WV600 57" Rear Projection...
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
THe standby light will blink a code that should be a repeating code. Please post the count here as that indicates which circuit has the fault. That info coupled with the model number above will allow us to explain what is broken and perhaps what parts need to be changed to fix it.
Jun 06, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
