Off site access to view security camara dvr
Our GE Digia DVR is connected into our network and has an assigned IP address. We are running Windows NT Server and CNET CNSH 1600 router. We are wanting the availability to access the Digia DVR while off site. Everything I read says that I need to configure the router but I do not have a clue how to do that. Can you help me please.
Access the router look for portforwarding and enable port forwarding assign a name to your camera
type in the port your camera use. ex 593
then type the assign IP for your camera ex 192.168.1.6
to access it type in your browser the your public IP ex. 209.45.0.0:593
read your ip cam manual for accesing it.
Posted on Nov 12, 2008
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
Remote access to Digia II return error : Check Digia2.ecx installation. Current version is 1.0.1.0 Firmware on Digia II is 1.0.87
Go to: Controlpanel -> Internet Options -> Security (tab)... Chose ''internet'' and press the ''Costum levle'' button.. Set alle ''active X controls to ''(not secure)'' and press ok, and apply.. UNDO THESE SETTING ONES U HAVE INSTALLED THE ACTIVE X ADDON, FOR YOUR ONE SAFTY!
Jul 21, 2011 | General Electric GE Security Digia II DVR
I can log into my system using ie 7 and windows xp however the live camera mode is not displaying anything but black colour and the name s of the camera location are distorded. I can access and view on any...
Try removing the plugin and reinstall if it is there. It is possible the plugin did not install properly or it was blocked by security settings. You may have to lower security settings temporarily while you install and may have to enable active x settings.
Dec 01, 2017 | GE Digia II MPEG4 DVR (4Channel 120100FPS...
I can't access via browser to the Digia II because appears the message: "Please check the Digia2.ocx installation. Current version is 1.0.0.70. I'm using Internet Expplorer 8.
I can't access via browser to the Digia II because appears the message: 'Please check the Digia2.ocx installation. Current version is 1.0.0.61.I'm using Internet Expplorer SP2
Jun 24, 2010 | General Electric GE Security Digia II DVR
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
I have a shr 1041, I can view on computer using network cable but do not know how to view off site. any help? Thank you
Your DVR has a built in webviewer. Connect the RJ45 network cable from DVR to your DSL router. Now the IP address of the camera is all you need to type in the browser to see it.
Let me know if you want to broadcast it over the internet as well.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 21, 2010 | Samsung 4 Channel Dvr
Not able to use remote viewing via no-ip
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Mar 06, 2009 | GE Security Bc 1500 2.5 Ball Camera, High...
Security First SDVS-1904 Setup (Not D-Link) Needing help with this. We installed the 4 cameras and the DVR. They're working fine. Now I'm trying to get it to come up on the computer so we can see the...
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Mar 04, 2009 | D-Link Securicam Network DCS-950G Wireless...
Computers & Internet Logo
254 people viewed this question
David Payne
David Payne
