Question about Samsung RS2630SH Side by Side Refrigerator
Smelly fridge` Hi, My Fridge smells. We have cleaned it out and there is nothing spilt in there it still really smells. It is 2 years old. Could it be the deodriser, how long do they last until you hve to change them?
  • 1 more comment
  • helen stockton Nov 13, 2006
    Hi the smell just appeared over a couple of days at first we thought it was a chicken which seem to lose it freshness but despite removing it and cleaning the fridge you can still smell this smell even when the dooris closed.
  • lamps28 Nov 17, 2008
    fridge stinks.
    i have cleaned it all including drip trays. i have left nothing.
    still stinks.
  • Clanini2002 Nov 29, 2008
    Our fridge smells when we open the doors. We've cleaned everything we could reach. didn't smell anything when we pend the back. My wife says it smells like chemical or plastic.
  • 237 Answers
Can you describe the smell or relate it to something common? Plastic, burned wires, fishy, rotted meat, etc. Is it only when you open the door or can you smell it outside too? Are the temps normal in the freezer and refer sections? When did the smell suddenly get noticed?
Posted on Nov 13, 2006
SOURCE:
Smelly fridge
Remove any old food and clean the refrigerator to remove any unwanted smells.
Hope that helps!
Jan 16, 2015 | Refrigerators
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Nov 17, 2009 | Refrigerators
How to clean evaporator beko fridge
I've tried to remove but can't. I've now resorted to soaking up the liquid in the reservoir with kitchen roll then spraying with general household cleaner and once again mopping up with kitchen roll. You could try a weak solution of bleach or a mixture of bicarb and water instead of general purpose spray
Sep 20, 2009 | Belkin F1DK102P 2-port KVM Switch
SMELLY FRIDGE
I would move the fridge and check what is under it.
Dec 07, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still...
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Aug 14, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
636 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
