Question about Sony Handycam CCD-TR87 Camcorder
I tried to clean the heads with a spray cleaner and a swab.
Now the handicam will no play the tape. The first few time I tried to load the tape, it would eject. It quit ejecting, but now will not play the tape. In order to eject, I have to cut power, then back on.
This is the problem your camera is wet(spray)
Try to dry the camera
Posted on Jan 13, 2009
Vcr hi-fi light blinking
You just have a dirty main video head. You can get a head cleaner tape or you can buy a tin of Servisol Video 40.
To clean with the Servisol, remove the top cover of the VCR. You will see a big shiny video head. Spray that head with the cleaner. You can also wipe it over with a cotton bud if it is very dirty. It's a good idea to clean all the surfaces that the video tape touches. If you don't know which, when you first take off the cover with the VCR on power, put a video tape in a press play then watch where the tape runs. Eject the tape, then clean with the spray and a cotton bud. You can even spray the cotton bud and then clean with that if you are not happy just spraying into the unit.
Make certain that the sprayed areas are dry before trying a video. It dries very quick anyway.
Jan 29, 2014 | Panasonic Pv-7451 Omnivision Vhs Vcr W/...
Tip
How to clean a VCR tape machine.
You just rented a tape and your VCR will not track properly or you tried to record a tape and it would not play back. You have a dirty machine.
Remove the power. Remove the top cabinet by removing all the screws on the back and probably a few on the bottom. Once the top is off look to see where the video tape comes into the machine. Directly ahead of the input is the video drum assembly. It should be about 2 or 3 inches in diameter and be directly in front of the tape slot. It is very fragile and should never have any cleaning device moved up and down on it.
Once you locate the video drum you should saturate a cotton swab with a 100% alcohol solution and while turning the drum slowly with the swab pressed against the video drum you should be able to clean the heads.
The heads are very small and very fragile. Any vertical movement will break them. After cleaning the video heads move to the erase head, CTL head and audio head.
The erase head is located to the left of the tape path entry to the video drum assembly. The CTL head is located with the audio head on the right side of the tape exit from the video drum assembly. Using a swab saturated with alcohol clean all these heads.
You should also clean the tape path and load mechanism ( the tracks that the tape guides slide on). Clean the pinch roller and capstan.
All cleaning supplies such as 100 percent alcohol and lint free cleaning swabs are available at http://www.mcminc.com .
This should complete the cleaning of your VCR. If all went well the unit should now work.
Thanks for using FixYa and for the great rating.
hardrocko
on Sep 12, 2010 | Televison & Video
I'm getting lines and mosaics on the video tape output of my Sony DCR-HC40, and a message on the viewing screen to use a head cleaning cassette. After a minute or so the lines go away and the video is...
NEVER try and manually clean your heads in your camcorder. The drum assy and heads are much more fragile and easily damaged than that of a VCR. NEVER spray any type of liquid/chemicals in or on your camcorder. A Sony miniDV head cleaning cassette is what you need. There are other brands out there, but Sony is hands-down the best. When using a head cleaner, play it for only 5 to 10 seconds at a time and then try your tape again. If it has improved, but still has problems then play the head cleaner for another 5 to 10 seconds. Hope this has helped. www.austintelstarservices.com
Sep 01, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
My DCC 900 play all kinds of tapes but without sound. Even the meters apears. How can I clean heads.
You can buy special head cleaner but all it is is isopropyl alcohol; same as most lens cleaner. Rubbing alcohol contains lanolin and leaves a residue so it is not recommended.
Put a few drops on a cotton swab (q-tip) and wipe them off.
Unfortunately this sounds more like an amplifier problem or a bad connection which is a little more complicated then a head cleaning.
Cheers,
Kevin
Feb 10, 2010 | Philips Audio Players & Recorders
I have a 4 head hifi stereo sylvania video with a tracking proble
You might try to clean the heads, You can buy some acetone at any walmart, Kmart ect…Use a foam swab to clean the heads on the chrome cylinder that spins. (Do not use cotton swabs, it will get caught in the heads.) It has 4 small windows on the cylinder that are the record and play back heads. Do not use a lot of acetone at one time, just a bit. Let it dry for 5 to 10 min’s. Then try to record and play back something. Sometimes it takes more than one cleaning. But.. Always let it dry good before putting in a tape or it will clog the heads worst. I have found that cleaning tapes only work if the heads are not very dirty. A manual cleaning is the best. Radio shack may carry the foam swabs. I’m not sure but electronic supplies do. Hope this is helpful.
Nov 02, 2009 | Televison & Video
My jvc vcr is plugged into my new mitsubishi DLP tv and the image is jumping up and down a bit. It also seems to skip a few frames, why is that?
Nov 01, 2009 | JVC HR-A32 VHS VCR
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
No picture
This type of problem may be caused by a dirty video head, people some time try to adjust tracking to take care of this problem this is a mistake. Now to clear up this issue first you put the tracking control mid way in its setting, then you clean the heads of the VCR you can use a head cleaning tape (follow the instructions on the cleaning tape box)for this or if you have experience you use a chamois swab type cleaner (follow the instructions on the package of swabs and liquid cleaner). one the heads are cleaned you acn then try to adjust track to obtain the best picture. If you can not you may have video head problems or a problem in the drum motor (servo) mechanism. In which case I advise taking the unit to a TV repair shop.
Sep 13, 2007 | RCA VR552 VHS VCR
Bad picture
try cleaning the tape path, especially the rubber pinch roller, with an alcohol swab....but how is the performance as a web-cam? (when connected to pc)? if same result, then problem is deeper, maybe CCD
May 31, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Picture Problems
this is a tracking problem...try cleaning the entire tape path with alcohol swabs (open top cover), especially the pinch roller
May 27, 2007 | GE VG4052 VCR
Sony Handycam CCD-TR87  Camcorder Logo
140 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
