Question about GE Washing Machines
When we start the washer dose not keep the water insid going out right away in the same time befor the wash
    Scholar:
  • 61 Answers
Basic engineering princaples water will take the easiest path, if your drain is lower than the washing machine fill level it will run through the machine to the drain. raise the drain pipe to above the top level of the drum that should do it. otherwise you have a faulty wiring and your drain pump is on all the time.
Posted on Nov 12, 2008
Miele 500 wont let powder release from draw and no water gets in to wash clothes so machine continues on washing
Fixing A Miele Washing Machine- Do It Yourself - YouTube
? 8:48
https://www.youtube.com/watch?v=lSkMUxXja24
Feb 25, 2014 - Uploaded by techtecher
Save money by fixing the Miele washer yourself. Easy to fix. DIY. ... My machine is flooding the kitchen when it starts into thedrain cycle I think..
[PDF]Operating and Installation Instructions Washer W 4842 - Miele
www.mieleusa.com/manuals_pdf/Residential/Washers/W4842_us.pdf
Instructions. Washer. W 4842. To prevent accidents and machine damage, read these instructions before .... Adding/removing laundry during a wash program .
Jan 25, 2016 | Miele Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
When my Maytag bravos washer starts to wash cycle it stops with an F 51 code. it dose it every time it agates
Cause: suds. The wrong detergent or the wrong amount of detergent, makes the motor overheat.
Why? In my opinion when suds are detected the program needs to make them go away for fear the clothes won't be clean. So the program makes the motor do extra work to try and fix the problem. The poor washer motor gets worked to death because the water ain't right. This washer is designed to work with a small amount of water. Only a tiny amount of soap is needed to do the job. Put a cup of detergent in there and the machine is gonna constantly run way past time to be done just to get rid of the detergent. This causes the machine to overwork the motor and destroy the rotor position sensor.
Feb 04, 2011 | Maytag Bravos MTW6600T Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Bad smell from washer despite wiping down insides with hot soapy water
Try a hot wash with recommended dose of soap (no garments).
Fabric softener can build up inside a washer over time, particularly if quantity of soap used is less than suggested on packet.
Mar 12, 2010 | Samsung Washing Machines
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Dishwasher problems
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
May 01, 2007 | Frigidaire GLDB958JS Dishwasher
Washing Machines Logo
53 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
