Question about Coby DVD-R 1000 DVD Recorder
No Display, but has audio. S-VIDEO shows black & white stripes.
Problem: Was working fine till one day all of a sudden the display won't work. The audio was still on. Initially I was using the normal Analog Video/ Audio connections. To troubleshoot, tried to connect S-VIDEO which was showing black & white stripes. Even opened the DVD recorder (I used to have some advanced level electronics knowledge a few years back - not now). Since I had spend $200+ on this, won't give up so easily. Resolution: (1) Googling led to this site. (2) Got a few tips from the great post by "DaninFuchs" - hats off to the guru. (3) Looked at the user manual quickly - no directions. (4) Closer look at remote - showed a key named "PS" which is used to switch from/to Progressive Scan/Interlace modes. Pressing this resolved the problem.
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Posted on Apr 06, 2007
preachw996
  • 1179 Answers
SOURCE: No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Posted on Feb 03, 2009
  • 15 Answers
SOURCE: I can get composite video signal from coby dvd,
Are you using component video cables for the component outputs on your tv? Plugging composite cables into component output generally will produce poor if any video.
Also, check the back of your dvd player to see if you need to flip a switch to enable component video output. Good luck.
Posted on Aug 21, 2009
  • 1340 Answers
SOURCE: I am having trouble in connecting the new dvd
I found your model information on a site which provided something I was going to ask you if I could not find it.DVD recorders need either a digital input from a cable box or a self-contained digital scanner(yours does not have this).So,you need to hook up as follows,External cable into cable box input,cable box output into DVD recorder input,DVD recorder output to TV coaxial cable input(usually labeled ant.)the screw on connector anyhow,you should know what I mean it seems.In this configuration,you should not need to turn on the DVD recorder to watch TV without recording because they usually have a bypass mode when there is no power on the DVD.If you have picture in picture(PIP),you should be able to use the main source to record and switch over to the PIP channel if you do not want to watch what you are recording.Do about a 10-30 second test of that just to make sure though so you don't end up all messed up.Oops.My bad...you do not have PIP.As long as the cable box is tuned to the channel you want to record,you should be able to use the TV's tuner to watch something else with no problem.When doing this on VHS recorders,sometimes the screen would get fuzzy and you would have to press the TV/VCR vutton on the VCR remote.I do not know if a DVD recorder will do it or not as I have yet to buy one,but when you do your test recording,you can mess around with whatever you want to see what happens so you will be fully prepared when you do it.If you need more help or have a problem/question,just comment here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Posted on Sep 26, 2010
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
My Touch sreen IQ 770 PC completely black out ... Windows not showing .How I solve the problem ? Thks
You need to determin if the display is defective or the video card.
Connect a know working display to your PC and if you are able to view the display, your video card is fine and the display must be defective.
Try connecting the display to another PC and see if it works, if not your display is defective.
I hope this helps.
Good luck and have a great day.
May 18, 2011 | HP TouchSmart IQ770 PC Desktop
Blank display
the LCD need replacing so take the phone to a mobile center and have them replaced it fopr you.
Jun 07, 2009 | Nokia N70 Cellular Phone
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
No color on secondary display
Dear Huzzah,
please try to re-install the software( driver) of Radeon 64mb 9550/X1050 secondary series maybe the software is crroupt, if still face the same problem then please contact to Vendour to replace this card, if this card is in warranty period.
Regards
Scorpionakku
Oct 07, 2008 | Diablotek RADEON 9550 Video Card - 64MB...
ATT Tilt - No Display at all
www.blackberry8100parts.com
they have the replacement screens for this phone
Aug 05, 2008 | AT&T 8925 Tilt Smartphone
No DISPLAY ON THE SCREEN
If the external display works fine then the most common fault is the Inverter board for the LCD. By having the external display function properly, the video signal from the video graphics card is working.
The other fault could be, but generally isn't, the TAB welds on the LCD. Usually when these go a portion of the display will be lost first or discoloration e.g. red/white/or black stripe appears.
I generally don't include the CCFL (Cold Cathode Florescent Lamps) as a fault as the inverter is what supplies the voltage to the lamps.
May 26, 2008 | Compaq Armada E500 Notebook
Coby DVD-R 1000 DVD Recorder Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
