Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven doesn't heat
I bought the oven last year and I used the oven 2 or three times and the oven doesn t heat properly. The support person said that it could be the calibration.
  • 833 Answers
I'm not sure what properly means.  If the unit is working, you can get a cheap oven thermometer to check the function of the thermostat.  Let the unit come to 350 and check the thermometer.  If it is off by more than about 20 degrees, there is a calibration change method in most oven handbooks.
If the unit is not working at all, this is another issue and needs a different set of diagnostics.
Posted on Nov 28, 2008
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven flame does not ignite
sure sounds like air flow problem
Aug 11, 2009 | Ovens
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
79 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
