Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Convegence sectors will not move
I have a mitsubishi model number wt 46805. the picture casts shadows especially when words appear on the screen. when i try to adjust the convergence sectors to match up the lines do not move.
    Scholar:
  • 146 Answers
The convergence ic's need to be replace. This should be done by a repair shop.
Posted on Nov 20, 2008
I have a WT-46805 Mitsubishi rear projection tv. The screen was accidentally pushed in and now has a crease. It was also missing the protective glass in front of the screen. I also have a broken model...
Check following image taken from related service manual that shows how to take off front screen from WT-46805 tv.
Hope this info will help you.
Please click HERE to download service manual copy, if required. It has schematics, parts list, exploded views and all technical info of WT-46805 tv. (service manual is available for 2 days only)
Thanks.
Nov 13, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 29, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805
Most probable cause is a cracked or bad solder joint on th blue CRT drive board which is the small board attached to the bottom of the blue CRT
Oct 17, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mits 46805 - Replaced IC's now picture is dim!
Good Day, Nickb2b;
The IC's you installed will not cause a dark/dim picture......but I would like you to check two things:
1. Make sure you put all cables that you may have unplugged into their proper positions, the cables are marked with numbers, ensure all cables are properly seated,
2. Look for fluid on the PCB's.
Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
