Question about HP LaserJet 2420 Printer
INK CARTRIDGE WILL NOT FIT BACK INTO THE PRINTER
ON THE RIGHT SIDE OF THE HP 2420 LASERJET THERE IS A WHITE ROLLER THAT IS PREVENTING THE CARTRIDGE FROM SLIDING IN PROPERLY. I BELIEVE THIS WHITE ROLLER SHOULD BE FLUSH AND ONCE THE CARTRIDGE ENTERS IT ASSISTS WITH THE DOCS FLOWING THROUGH PROPERLY????
The white roller is the hub that engages with the toner cartridge after it is installed. It is flush with the toner door open. As the door is closed the white arm attached to the toner door on the right side causes it to move inward. One possible scenario is that the tab on the door that it clips to is broken or the clips on the arm are damaged.
Posted on Dec 12, 2008
Black line down right side of 3050 laserjet
I would try a few of the following; try a fresh (clean) install of the printer on your pc; or try a firmware upgrade on the printer; or clean the toner cartridge transfer roller (it may even be scratched.)
Nov 23, 2013 | HP LaserJet 1020 Printer
The IT Dept. at work gave me a Laserjet 2420. When I print something, it appears that ink is stuck to the roller and will reproduce faded lines further down in the page. I would describe it as the toner is...
Faulty cartride or fuser causes ghoost image in print outs. Primary level:check with another cartridge. Secondry level: Remove fuser assm out, check teflon sleeve surface deposited with toner?. replace teflon sleeve if available if not replace fuser assm. In fuser modes we can increase/decrese the temparature of fuser.
Note: only service engineer can replace the teflon sleeve.. user not advisable
Sep 21, 2011 | HP LaserJet 2420 Printer
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Spring came loose under the roller
Hi niffieprinti:
If you remove the toner cartridge again and remove the roller (Registration Roller) one side of the roller has a gear and the other has a silver bar, well one spring goes under the gear on the left side and the other spring goes under the bar on the right side of the roller. The springs apply pressure to the paper against the toner cartridge so that the image is clean and dark. if you have any further questions let me know.
Thanks
pdouglasss
Apr 17, 2009 | HP LaserJet 8150 Printer
HP Laserjet 2420 will not print from tray 2
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Jan 28, 2009 | HP LaserJet 2420 Printer
HP 2420 Faded Print outs
Check (and remove) the "economode"in "Printer Preferences" (right click on Printer applet) normally in "Paper /quality" Tab
Jan 03, 2009 | HP LaserJet 2420 Printer
Printing with 6 black dots on right side
If the spacing between dots are the same, then you have a dirty or bad roller. If you never had this problem prior to installing the new toner cartridge, then I would suspect you have a bad one. Try a different toner.
Nov 18, 2008 | HP LaserJet 2420 Printer
Blank printing
Did you pull the plastic tape from the side of the cartridge?
Nov 14, 2008 | HP LaserJet 2420 Printer
Paper is coming out all black
The most likely cause is a faulty toner cartridge, replace it
Jun 10, 2008 | HP LaserJet 2420 Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
135 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
