Question about Sharp AL 1631 Copier
Copies have a void area the length of the copy approx 1 inch wide
Cleaned transfer charger
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Pull out your toner unit and look at the front to see if there is a missing spot on the roller where there is no toner. if not you probly need a new drum.
Posted on Nov 12, 2008
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Blank area on copies
Hello sir; There have two things to check it;
1. check the developer unit see the brush they build up is evenly.
2. have a piece glass under the toner unit, pull it out and clean it.
Aug 12, 2009 | Ricoh Office Equipment & Supplies
Copy is smearing from top to bottom on left side of paper about 1 inch wide.
The print in the smudged area, does it wipe off the page like not fused well to the paper. Do you also have a crinkling noise, if so the sleeve in the fixing assembly has torn. You may still have it under warranty with canon and can get it fixed for free.
Good luck
Bob
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Copiers
The Ai3010 - fading image at 200,000 copies = needs a new Optical Drum + Cleaning Blade + Main Charger Wire + Developer + Transfer Assembly.
Dec 30, 2008 | Office Equipment & Supplies
Xerox 6115
If this only happens when you use the Doc Feeder.. Clean the Slit_Glass, the little piece of glass next the large glass. Clean with a lint free cloth and alcohol.
If this happens when making copies from the main glass, it could be dirty mirrors/ lens, or internal problems.
if this happens when you print something from a PC, it is internal,
which could be a number of things?
something on the charge, the transfer, or your drum could be going and needing replacement, developer dumping, etc etc.
Oct 26, 2008 | Xerox Office Equipment & Supplies
Sharp AL 1631 Copier Logo
63 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
