Question about Iwill ZPC-SP (ZPCSP) Barebone
I have put a sempron 3.4 processor in but the system only recognises it as 2ghz ?
I put a 3.4 sempron procesor in but the system only recognises it as a 2ghz processor..?? It also comes up with the following in Device Manager. AMD Hammer Family Processor - Model Unknown Please HELP !?!
    President:
  • 2,961 Answers
Your processor speed is actually correct AMD calculate the clock speeds differently from Pentium type processors, a 3400+ is a 2.0 GHZ processor, see the list below for speeds Sempron 2500+ 1.40 GHz 800 MHz 128 KB 754 Sempron 2600+ 1.60 GHz 800 MHz 128 KB 754 Sempron 2800+ 1.60 GHz 800 MHz 256 KB 754 Sempron 3000+ 1.80GHz 800 MHz 128 KB 754 Sempron 3100+ 1.80 GHz 800 MHz 256 KB 754 Sempron 3300+ 2 GHz 800 MHz 256 KB 754 Sempron 3400+ 2 GHz 800 MHz 256 KB 754 Don't worry too much about the proceesor not being recognised as long as you know it is running at the correct speed.
Posted on Nov 12, 2006
What's your problem?AMD athlon 2Ghz processor will suitable for asusp5gc mx x-series motherboard
No... Absolutely not.
You can't put an AMD processor in a motherboard that only supports Intel processors.
Aug 17, 2012 | Intel Computers & Internet
Does Foxconn 6100M2MA-RS2H Motherboard BIOS support AMD Phenom 64 X4 procesor ?
I'm afraid not. Foxconn 6100M2MA-RS2H has an AM2 Socket that only supports the following processors: AMD Sempron, Athlon 64,Athlon 64x2,Athlon 64FX. Phenom processors support AM2+ and AM3 socket motherboards. Hope this helps. Any vote will be appreciated. Thank you :)
May 30, 2011 | Foxconn 6100M2MA-RS2H Motherboard
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
Hi i need more help in knowing just what type of processor chip to buy i know i need to put the same type back in my problem is i dont know what type it is my pc is acer aspire t135 1.8ghz it says on my...
Hi Paul,
Correct, you have to use the same type, but you can upgrade to a faster CPU.
According to the specs for your computer it can take the following:
AMD Sempron processor 2600+ to 3300+, 333MHz FSB
AMD Athlon processor 2800+ to 3200+, 400MHz FSB
See:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT135/AspireT135sp2.shtml
The Athlon's are better...faster Bus. The Sempron is cheaper.
The 2 processors you describe are very similar. The difference between the 2 is that the first one is capable of running 64-bit operating systems and applications. The second one is strictly for 32-bit systems.
The next question will probably be, "What do I have?" Probably a 32-bit system. You can go with the 64-bit CPU and be safe as it can run both. You can see what your old one is by the revision number on the top of the CPU. You can use the following comparison chart to see the differences:
Sempron 3100+ Comparison
I hope this has been some help. Maybe it has just caused more questions. Just ask.
Thanks for using Fixya.
Mar 24, 2010 | Computers & Internet
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
I need to run Autocad 2010 on my computer but it won't even instal because I have an AMD 3000+ 2Ghz processor. Is it possible to upgrade the processor without buying a whole new computer?
Autocad 2010 needs SSE2 to run.
The only Semprons which didn't have SSE2 are those for socket A, so I assume you're running a socket A mainboard. I checked and there are no socket A processors that support SSE2 unfortunately.
I think that you could replace your mainboard and the cpu cheaply witha a socket 754 mainboard (which supports SSE2 CPUs and should run with your old ram).
However I advise to upgrade to newer system with AM2 socket or so - they aren't expensive and the increase in performance in power-hungry applications such as AutoCad will be noticeable.
Oct 12, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
New procesor not work
you might check the jumper for processor settings, maybe the jumper is not set to celeron? if it is working using the intel pentium check the specification of the mother board if you can use the celeron processor.
Mar 15, 2009 | Computers & Internet
Problem with Turion Ml-40
You can buy the same processor and it costs around $165.  Check this link: http://www.dealtime.com/xPO-AMD-AMD-TURION-64-MOBILE-ML-40-2-2GHZ-35W-L1-128KB-L2-1MB
And for the second part of the question, i did not really understood whats the problem.Can you be more clear... Can u give me the error message,the OS you use and which program makes it to freeze?
Generally this freezing happens when the processor is getting overheated.You may have to change the thermal coolant paste applies to the processor.Check out with your nearest hardware expert.
Nov 01, 2008 | Computers & Internet
Iwill ZPC-SP (ZPCSP) Barebone Logo
143 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
Nathaniel Berrios
Nathaniel Berrios
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
