Question about Cycling
Assembling of rear hub
I have the hub disassembled and cannot fit it back together
  • 37 Answers
You need about 5 bicycle specific tools, refer to Parktool.com
Posted on May 26, 2009
Need replace the rear wheel studs on 2004 mercury mountaineer 4.0 6 cyl AWD
replace the whole hub assembly with new bearing and hub kit hub must be presed apart n presed back together yo
Dec 19, 2012 | 2004 Mercury Mountaineer
Wheels keep coming off
1 - Remove rear wheel
2 - Remove posi screw from bottom of rear wheel hub assembly
3 - Allow bottom block and spring to fall into palm of hand
4 - Push rear wheel lock bottom down through rear assembly to remove.
5 - Clean wheel lock button and locking plate to ensure free movement.
6 - Clean rear hub and locking button housing with dry cloth.
7 - Apply lubricant thinly in recess to allow free movement of button (dry Teflon spray is best - find it in the laundry aisle of larger supermarkets)
8 - Re-fitting is reverse procedure of removal instructions.
Nov 30, 2011 | Quinny ZAPP Stroller
Which is cheaper to fix,front or rear wheel bearing on 2005 trailblazer?
Front wheel bearings are expensive because they come as an entire hub assembly, but the labor isn't too bad, maybe 1 hour. The rear bearings are relatively cheap, but the labor to get to them is long. The axle has to come out, so that means the differential needs to be opened. The brakes have to be disassembled. Depending what kind of deal you can get a front hub assembly for, the rear bearings will probably cost you more.
Aug 26, 2011 | 2005 Chevrolet TrailBlazer
Do i need any special tools to remove and replace the rear wheel bearings on a 1991 ae95r corolla? or can i manage with a pretty basic tool set? cheers.
the rear wheel bearings have to be pressed together, you have to remove the hole hub assembly and then have some one press the hub apart and back together, so what i am saying is that you can remove the hub assembly with just some basic hand tools but unless you have a press you can not replace the bearing.
Feb 04, 2011 | Toyota Corolla Cars & Trucks
Whats it take to install a clutch hub for a 1988 police bike flhpt
To install a clutch is not what I call an easy job but not an extremely difficult job either. You are going to need some special tools however.
The tools you'll need are an impact wrench, a large socket to fit the compensator nut and one to fit the mainshaft nut, a primary locking bar, torque wrenches that will torque to 150 foot pounds and 70 foot pounds in the left handed direction, and a special tool required to disassemble the clutch assembly.
First, disconnect the battery, then drain the primary and remove the outer primary cover. Use the impact wrench and appropiate socket to remove the compensator sprocket nut from the engine shaft. Remove the snap ring holding the release plate in the center of the clutch assembly and remove the LEFT HANDED THREADED mainshaft nut. Take the nut off the chain tensioner and remove the primary drive (engine sprocket, adjuster, and clutch assembly) as a unit.
Now, using the special tool, compress the clutch spring and remove the lock ring holding the clutch assembly together. Disassemble the clutch and reassemble it with the new clutch hub. Reinstall the primary drive. Apply one line of Loctite 271 inside the mainshaft nut and torque it to 70-80 foot pounds LEFT HANDED. Apply two lines of Loctite 271 (red) to the compensator nut and torque it to 150-165 foot pounds. This is what the locking bar is for, to keep the engine from turning while applying the torque to these two nut. Adjust the primary chain and reinstallt the outer primary. Add about one quart of lubricant to the primary. Reconnect the battery. Adjsut the clutch and cable.
Good Luck
Steve
Sep 17, 2010 | Harley Davidson FLHRI Road King...
I would like to know if the wheel bearing is in the shaft or the hub?
The Constant Velocity (CV) joints are located on the inner and outer edges of the axle shaft. The axle shaft runs through the hub and bearing in the spindle.
Jun 16, 2010 | 1999 Daewoo Nubira
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
Rear wheel bearing hub replacement on a 2002 pontiac grand prix
It is a tight fit, a few wacks with a hammer should loosen it. Hit on the back side of the flange where the wheel mounts, try to drive it away from the car, after making sure you have removed all the bolts.
Apr 03, 2010 | 2002 Pontiac Grand Prix
Can't get chopper blade assembly back together in proper spot
if you rinse dishes well;the blade can be discarded,as they can be nearly impossible to reinstall
Mar 10, 2010 | Dishwashers
Replacing front rotors
you do have to dissasemble the hubs because the rotors bolt on to them. if it is two wheel drive take the center caps off of hubs remove the spindle nuts and bearings pull complete hub assembly off and unbolt rotor from hub. if it is four wheel drive you will have to remove the lockout assembly be careful not to loose any parts from this it won't work when put back together.
Aug 26, 2009 | 2001 Isuzu Rodeo
Cycling Logo
311 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
