Question about Philips 50P8341 50" Rear Projection Television
Audio cutting in & out
We have a philips60in.rear t.v.60p8341 ,the audio is cutting in& out.we are finding out that the satellite remote is changing the t.v. brand on the settings panel, when we change it back the volume comes back on.we are wandering if you big-e happen to have a satellite hooked up to your 50in. t.v.& if so check your remote settings for the set-up.
2 Suggested Answers
SOURCE: 60P8341 Rear Projection - Remote does not work
I PUT MY TV IN THE SHOP AND THEY REPALCED THE SYSTEM CONTROL CIRCUIT. MY UNDERSTANDING WAS THE EPROM. THE PERSON I GOT THE TV FROM HAD IT IN THE SHOP TWICE FOR THE SAME PROBLEM BEFORE I GOT IT. KNOW THE REMOTE WORKS WITH NO PROBLEM.
Posted on Jan 14, 2008
Where would i find a replacement remote
$40.95 at partstore
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/60P8341/Royal+Philips+Electronics/Philips/312814712082/New.aspx
Also check www,replacementremotes.com
Sep 28, 2010 | Philips 60P8341 60" Rear Projection...
Tip
No Audio or Video
If your Magnavox TV powers on but has no audio or video check out the repair tips and kits at www.magnavoxhelp.com
on Jun 24, 2008 | Philips 60P8341 60" Rear Projection...
Where can i find a new key bord part #313501707611 its for a phillips model # 60p8341
Try http://www.encompass.com They have the best selection of parts at the best price. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 18, 2010 | Philips 55P8241 55" Rear Projection...
Screen is to big
Either the TV or the cable/satellite receiver has Zoomed in to the image when parts of the picture are cut off. Look at both remotes for a Zoom feature or the onscreen menu's for any settings. Usually TV settings don't change on their own but cable/satellite receivers can receive updates and it may need to be reset afterwords, much like a PC.
Oct 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound from a Philips model 60P8341...
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Jul 03, 2008 | Philips 60P8341 60" Rear Projection...
No sound
check your remote to see if it's on mute...or mute is enabled...check your connections from the tv to the cable box...if your using surround sound...check those connections as well...if you have a dvd player..hook it up to the tv and see if you get audio...let me know if this helps...if not i will give you more things to check
Feb 07, 2008 | Philips 60P8341 60" Rear Projection...
Screen cut off on the bottom - WT-42313 Mits 42"
Make sure your remote is the official Mit remote, and that it is set for TV, usually the far left setting at the top of the remote.
These remotes control many different devices. Some will allow video to work without allowing audio to work.
TV will allow all to work.
Mr Bob
Jan 23, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Philips 50P8341 50" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
