How to program Direct TV remote
I am having problems programming my Direct TV remote. This model # is not listed on the programming screen.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 122 Answers
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Posted on Apr 11, 2012
2 Suggested Answers
SOURCE:
SOURCE: need to program rca universal remote for symphonic tv model SC313E
the code is 033
Posted on Nov 08, 2008
How do i restore my signal for Direct TV?
I understand the problem you have is the remote not controlling the TV?
If so, set the remote to TV and hit a button. it should ask you Manufacture and give a list of codes. If this does not work, go to Directv.com and look up how ton program remote. Directions should be there. Or just google the question.
Sep 02, 2014 | Televison & Video
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Cannot change from video mode as we have no remote. We have a GE TV model 31gt660 which was hooked up by Direct TV. However, when the boys decided to hook up a flat screen to watch the fights the GE was...
My only suggestion would be to purchase a multi-functional remote that you could program to your TV. Now some remotes have to be programed buy your old remote. That is not what you need. You need the kind that comes with a little book that will list your tv model number and give you a code (usually 4 numbers) to teach it to talk to your tv.
Sep 20, 2010 | GE 31GT660 TV
Program direct tv remote with our sylvainia 42'' flat screen
Here's the directv web site link to show you how to do it.
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020
There is a possibility that the list of codes will not work. But, they will show you how to program the remote to search the whole codes list stored inside the remote. Good Luck. :)
Jun 06, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Program remote for direct tv receiver
Not a problem - here's a site that was built just for that problem. http://www.remotecodelist.com/remotes/
Simply scroll down through the list of remotes and locate the remote. Then click on the link to find a host of codes and procedures to program that remote for almost any device it's capable of operating.
Hope this helps!
Bill
Dec 04, 2008 | Frigidaire Control
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Direct tv remote code
Here is a copy of the manual if you don't have one
Remote control programming starts on pg 76-78
If the tv isn't listed on the on screen controls, you might want to check with Direct TV on getting hold of another remote that can be programmed. Sometimes software update are done to the tuners as well but usually there never done for adding new models to TVs.
One thing I never liked about Direc TV was I always had to update the TV tuners every two years because of new features.
Sep 05, 2008 | LG 42LC2D 42 in. LCD HDTV
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Jun 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
884 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
