Question about Samsung TX-R2735 27" TV
Blue screen Hi there, The TV started to delay in getting a picture when we turned it on. It would just start with a blue screen and then eventually (20 seconds or so), the TV show would appear. The delay got progressively longer and now it just has a blue screen and no TV show appears.
    Problem Solver:
  • 12 Answers
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Posted on Nov 13, 2008
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
My ASTAR 32 inch has no picture or sound for 10 mins on start up. Happens if tv has been turned off for a couple of hours. I get blue screen then snow screen and eventually picture will come up but may be...
This is typical of dried up old capacitors. The problem can be cured by keeping the TV on for days. The moisture in the air will be the cure for the dried up capacitor. It will be good as new if you use more frequently.
Nov 04, 2010 | Televison & Video
You have an AC resistance problem on the interface board. Passive components such as silver mica and electrolytic capacitors are not charging and discharging properly. This causes a delay or disruption in the start-up process. Byte signals are weak and intermittent due to other thermal components failing such as 'diodes, smd mosfets,...etc...''' Believe it or not this happens from manufacturers using 'inferior-grade' circuit components that fail under considerable load conditions. By replacing a few parts with better quality parts will solve this issue for you. To replace these parts requires removing the back cover and using some test equipment. If you can get someone who is technically proficient I can e-mail them instructions on how to fix this problem on the circuit board.
Let me know if you want to follow up on this...
Dec 07, 2009 | Astar LTV-3201 32 in. LCD Television
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
Blue vertical lines on tv when turned on....now no picturs.
the guns gone bad inside needs to be replaced.
Apr 22, 2009 | Televison & Video
Sony kp57ws500. Screen starts ok, then starts to turn blue and eventually (within a couple of minutes) completely blue. what can I do? is it the bulb, board ?
I have this very same tv and I also had the very same problem! Its not the bulb! Your flyback power converter on the D circut board needs replaced! (the part is $70.00 and you can get it at www.sears.com the parts dept!) the flyback is a high voltage holder so a pro will have to do the repair!
This should fix ya!
Please rate my response!
THANK YOU! PS if you let the tv on The picture may come back on after warming up for a wile longer (little by little)
Jan 15, 2009 | Televison & Video
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Possible picture tube problem? Delayed picture, blue background, etc.
U should have a lamp in this unit replace it very costly but will need to be replaced and it is better for a repair man to come in and comfirm
Dec 12, 2006 | RCA HD52W56 52" Rear Projection HDTV
Samsung TX-R2735 27" TV Logo
424 people viewed this question
Jerry Greenberg
Jerry Greenberg
