Sony PlayStation Portable (PSP) Console Logo
Posted on Apr 11, 2012
When i put paaword its error come 80410d09 says put hexadeimal or ascii character
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39
Points
Try going to youre settings and restore youre settings will delete everything but might work remove memory card first so you doint lose data or try 0000or 1234
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Ascii characters on ASUS X101h
Read at http://www.asciitable.com/
2answers
What is the ascii equivalent of that "window key" in the standard keyboard?
Hi there! Keys like the Windows key don't have an ASCII value. Only keys that are 'printable' have an ASCII value. To detect keys like the Windows key you have to use either the Key Down or Key Up events and use the Key Code to detect which key was pressed. You can find the values for Key Codes on MSDN
Hope this helps!
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Decoding properties EAN128. I need the data separator not to be removed (FNC1) for variable lenght application identifiers. How do i have to configure the 4410
If you generate your own barcode font, you may find the FNC1 character in the manual. In the ascii table for the font generator we use, the FNC1 character's ascii value is 102 +32 and is coded as (chr)134 in the code128c string. Most Iinfo online suggests the ascii character is 202 or 234 (?) or the character defined as "capital E with the circumflex", but that did not work for our barcode font.
MA101 gives error message regarding password
i want to use a wireless lan connection in my laptop what i need to buy thnx
3helpful
WiFi Password error Msg 5 or 13 ascii characters or 10 or 26 hd
hi there,
go to the router settings page on one of the computers connected to the network.
open the web browser.
go to http://192.168.1.1
username and password is: admin
then on the tabs you should see secruity and your password will be in there.
just remember when you connect you need to maybe press a button on the router to put it in pairing mode.
hope this helps
4helpful
VBScript compilation error ''800a0408''
The Symptoms you get The script does not execute as you had hoped. Instead you get a WSH message box.
The Cause of error 800A0408 Your VBScript contains an illegal character, often at the beginning of a line. It can happen if you copy the script from word, then paste into notepad. For example, to 'Rem out a line we need the apostrophe, which is ASCII character 39; however if you paste from word you may get ASCII 96 (Grave accent).
Note the clue Source: Microsoft VBScript compilation error, this means a syntax error in your script.
The Solutions Check the punctuation marks in your VBScript, particularly look out for apostrophes and commas that do not display correctly. The reference to Line: 1 Char 1, means that the very first symbol that is probably wrong.
Psp not accepting wep key
You need to choose the correct security setting before you enter the WEP key where it asks you if its WEP. ASCII or unencrypted choose the correct one!
2answers
Intermittantly Prints pages of ascii characters
Check your USB or Parallel cable what you are using. If not solved connect the printer to another pc . Some times computer port may get damage.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
