Question about Frymaster Dean Kitchen Appliances - Others
Pilot light not staying on
Commercial dean fryer replaced the gas valve with a honeywell 8071604 and the thermopile #205T102 when releasing the pilot everything goes out. can you solve this. have a diagram of the correct posistioning? thank you.
Has the hi-limit been checked?
Posted on Nov 19, 2008
Commercial propane fryer wont light
If the pilot won't light, the first thing to try is to replace the thermopile, assuming you have a good flame on the top portion of the thermopile in the first place when you hold the gas valve in when in the pilot position. If this does not solve the problem, which in 90% of the cases it will, the gas valve is defective. I usually replace the thermopile when replacing the gas valve and save the old one for a backup.
Feb 06, 2014 | Vulcan GR45 Deep Fryer
Pilot lights however when I turn the temp up to where I want it set to pilot goes out. The thermostat makes a ckicking sound when I tune it right before pilot goes out
Hi there.
Verify if the gas pressure fed to the fryer is correct. Check also for errors/ loose wire connections on gas valve, thermostat and hi limit, last possible cause, the thermopile is weak and cannot give enough power to energize pilot and main valve at the same time.
Regards.
Aug 14, 2013 | Dean SR14E Deep Fryer
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
My deep fryer pilot somtimes goes out after burners ignite
I assume this is a natural gas fryer....Are your jets clean? That is an issue sometimes, and those are the small holes that your flames come out of....Is your gas line clogged anywhere....? I don't sell Dean fryers, not too impressed by that brand, as they leak quite often, and then Dean won't honor their warranty program....so I'm not as familiar with their products, however on some brands, the thermostat dial itself should not be turned to the holding temperature until after it lights and is fully on...Do you turn it to say 350 degrees right away or wait for it to light before selecting your temperature? Thermostats themselves going bad is the number one issue with fryers, so it could be that. To clean out the burner jets, we use a compressor and blow them out clean...You can also use a small brush or skewer to clean them out. I would eliminate everything you can that has no costs involved first, and then move to parts that you have to purchase. If you need a thermostat, I could get you a price on Monday... Our toll free number is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We would need the brand/model number and serial if you have it also. Our service tech who specializes in gas products is off Monday, but there are other people there who can help and get you pricing on parts. I won't be in until after lunch myself Monday, but check out what you can, and if nothing works, then call us on Mon or Tues next week.
Everything is closed up until Monday, so we can't order or get pricing over the week-end. Good luck, hope this helps.
Susan
REO
Nov 22, 2011 | Frymaster Dean SR42G Deep Fryer
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
Hi, The pilot light wont stay on when I release the gas before swithing it to the on position. Can you help
check if the thermopile receives enough heat from pilot flame, if it does, replace the thermopile.
Mar 29, 2011 | Frymaster Dean SR142GP001 Deep Fryer
Open Questions:
Kitchen Appliances - Others Logo
431 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
