Question about Zanussi IZ12 Front Load Washer
Where can I order a new belt for my Zanussi IZ12 wasmachine?
It's a frontloader wasmachine (Zanussi Jetsystem), model IZ12, Type P6747639, productnr 914513012/00, serie nr 01100327, made in Italy, 2200W, 220-230V-50HZ. I bought it in Holland (Europe) in the year 2000 and I'm reciding in Bonaire (Netherlands Antilles, the Caribbean) for two years now. Thanks!
    President:
  • 1,462 Answers
Bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Posted on Nov 12, 2008
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Washer won't spin.
check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
Jul 24, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
240 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
