Question about Rode NT-2000 Professional Microphone
Nt-2000 is making noises (clicking regularly and other noises)
Not sure if it has to do with too much input - was so in the beginning, but now is always making noise, cannot record with it anymore.
joy
  • ronkhoo Feb 03, 2009
    Have the same problem, appears to be related to the polar selection dial, when I spin it, the noise comes and goes, but mostly it is now there all the time.
    Ron
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
This is a typical component failure issue. The mic will need to be professionally serviced. Condenser Microphone Mod Service
Posted on Feb 06, 2014
On my 2000 camaro ss clutch pedal is making clicking noise at the begining of pressing it in and at the end of when i release it.
Do you feel this click when you push the pedal downwith your foot? Can you see if any wiring or anything is rubbing the arm connected to the pedal. SS camaro probably has a heavy duty clutch.Cheers Denny
Oct 11, 2013 | Vehicle Parts & Accessories
What kind if any noise will the transaxle make if bad.
TURN THE WHEEL ALL THE WAY TO THE LEFT, DRIVE THE CAR YOU WILL HEAR A CRACKING NOISE IF THE CV JOINT IS BAD.
DO THE SAME WITH RIGHT SIDE.IF YOU HEAR ANY NOISE CV JOINT IS BAD.
May 07, 2012 | 2000 Oldsmobile Alero
Turning noise
You most likely have torn outer CV boot and an outer CV joint that is going bad.
Nov 12, 2011 | 2000 Hyundai Elantra
The stain vanish and 90 minute lights are flashing but the cycle has'nt finished.begins to spin but makes a banging noise and then stops.not taking fabric softener neither.
Sounds like multiple problems. A banging noise during spin means that the drum is not centrally balanced or the suspension mounting is loose or broken. The machine needs to be examined by an experienced technician.
May 27, 2011 | Washing Machines
Engine makes a whining noise has the rpm's go up in all gears including park and neutral.
COULD BE, BUT NOT SURE, CHECK YOUR WATER PUMP. THATS A BEGINING STAGE SYMPTOM OF A WATER PUMP GOING BAD
Nov 10, 2010 | 2001 Ford Ranger Regular Cab
Clicking noise in place of grinding and dispensing liquid;
Hi
Your brew gear drive is broken. Your doser knob is det to the max and you got an over charge in the brew unit that the drive could not compress and it broke some of the teeth on the gear. You will have to replace the gear and make sure that it is timed before testing or you will break it again.
Jul 30, 2010 | Spidem Trevi Automatic Espresso Machine
Virtual device driver format in the registry is invalid
Windows XP instructions:
  1. Click Start->Run and type Regedit. Click OK
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\VirtualDeviceDrivers
  3. Delete the VDD value
  4. Click Edit->New->Multi-String Value
  5. Name the value VDD, press Enter
Windows 2000 instructions:
With Windows 2000 you must use regedt32.exe instead of regedit.exe. The regular regedit will not allow you to add REG_MULTI_SZ's for some odd reason and a regular string value will not work in this instance.
Aside from that, the instructions are the same.
It also may be necessary to extract the original autoexec.nt and config.nt from your Windows CD, as they may be corrupted.
  1. Click Start->Run and type expand x:\I386\autoexec.nt_ %systemroot%\System32\autoexec.nt (Where x: is your CD-ROM drive)
  2. Click Start->Run and type expand x:\I386\config.nt_ %systemroot%\System32\config.nt
  3. Click Start->Run and type expand x:\I386\command.co_ %systemroot%\System32\command.com
Jan 29, 2010 | Computers & Internet
I have a brand new relay yet my fuel pump will not respond on my 1998 Honda NT 650. ANY SUGGESTIONS? Thanks.
Are you sure it doesnt respond? i thought the same and even bought a new one still no change.
I found out the if you empty the pump of fuel and the line leading in that you"ll hear it over the engine noise as a slight clicking noise till it gets full and quiets down. also i took on of the line off just to make sure the gas was being pumped out when it was quiet.
Sep 03, 2009 | 1991 Honda NT 400
My AR-5316 dont work in network with computer i am using. it shows that "required user intervention" when i am printing cadd drawing.. what should i do?
Before starting the installation, make sure the USB or parallel interface cable is not
connected to the MFP.
Insert the supplied CD-ROM into your CD-ROM drive.
Double-click "My Computer" (
), and then double-click the
CD-ROM (
) icon.
When any of "Hardware Found", or "Found New Hardware Wizard"
messages appear during the software installation, be sure to click the
"Cancel" button.
Double-click the "setup" (
) icon.
If the language selection screen appears after you double click the
"setup" icon, select the language you wish to use and click the "Next"
button. (Normally, the correct language is selected automatically.)
Select the software packages to be
installed, and then click the "Next"
button.
The software packages with checkmark (
on the list on the screen will be installed.
Click the "Display README" button to show
the information on the selected package.
In Windows 95/NT 4.0, "Button
Manager" does not appear. In
Windows 98/Me/2000, do not select
the "Button Manager" checkbox.
because this is not supported when
using the parallel interface.
5
The next screen appears. Make sure that the parallel interface
cable is not connected, and click "OK".
Windows 95/NT 4.0 Windows 98/Me/2000
6
Check the contents of the package on the screen, and then
click the "Start" button.
The software packages to be installed will be displayed on the screen. If
inappropriate packages are displayed, click the "Back" button to select only
appropriate software packages.
28
7
Copying files for MFP driver installation and parallel interface
setup (This step will start if it was selected in step 4).
After confirming the message in the "Welcome" window, click the
Aug 06, 2009 | Sharp AR-5320 Black and White Copier
2000 MALIBU WILL NOT START
battery side post terminals sometimes get a coating of dirt on them you need to look hard and scrape off or the cables are bad
Sep 23, 2008 | 2000 Chevrolet Malibu
Rode NT-2000 Professional Microphone Logo
170 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
