Question about Brother IntelliFAX 2800 Laser Fax
Paper will not feed through the insert opening
The paper will not feed through the opening where you insert a sheet of paper that is either going to be faxed or the paper that you want to copy. You have to keep your hand on the paper and apply slight pressure to guide it through.
    Genius:
  • 2,120 Answers
Lift up the cover for the document feeder and clean the roller and pad with alcohol.
Posted on Nov 13, 2008
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
My photosmart C3150 printer keeps feeding many sheets of paper when it goes to print. This causes a paper jam. How do I get it to only take a single sheet?
Try cleaning the rollers with purified water. See instructions here. Also make sure you fan the paper before loading, try flipping it upside down, and see here. If you have no luck, try another brand of paper, or loading more or fewer sheets...
Good luck, that's a frustrating problem...
Jul 30, 2009 | Office Equipment & Supplies
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
