Question about Acer PD120D Multimedia Projector
Acer PD120D Projector powering off after only 3mins.
My projector just shuts down after about three minutes. The cooling fan seems to be running fine when it's on. The brightness of the bulb doesn't appear to have changed or dimmed. It takes about an hour of sitting before I can power it up again. I have no idea how many hours may be on the lamp, but I can't imagine it is over 200.
  • Anonymous Apr 26, 2009
    Same problem here!
SOURCE: Projector won't power up
my Hitachi CP-S210 Multimedia Projector
will not power up at all.
Power sorce is good. Turned off last night, but will not do anything today. HELP
Posted on Jan 04, 2008
  • 5 Answers
SOURCE: sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Posted on Jul 10, 2008
freetek
  • 5568 Answers
SOURCE: Won't power up at all
There is a chance that it is fuse protected inside.
When a filament-equipped lamp fails, it can create a momentary surge; you've probably seen this when a standard tungsten bulb flashes very bright in the process of dying completely.
If you no longer have the User Guide, you can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD120-_E
It may contain information about any fuse it uses.
Posted on Aug 25, 2008
  • 14 Answers
SOURCE: proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Posted on Sep 14, 2008
  • 2385 Answers
SOURCE: I just replaced the lamp
this is our chat session, please rate it inappropriate it will spoil my rating.
vsurg: thanks
cmptrlink: welcome
vsurg: I purchased the bulb through electrified.com. OEM replacement for $249. Is there a difference between bulbs?
Read more cmptrlink: yeah the lamp should be purchased after proper specifing the device model, or the recommended lamp specified by the vendor
vsurg: It is the right lamp. Of that I am sure. The projector is a Sony VPL-HS51.
cmptrlink: hang on i will tell you the correct lamp number
vsurg: Manual says LMP-H130.
cmptrlink: is that the same one you got?
vsurg: Yes
cmptrlink: why dont you consult to a authorized sony service center.
cmptrlink: the lamp no. LMP-H130. is correct. but there must be some problem with the lamp or projector! is the lamp was packed when you got it?
cmptrlink: the projector normaly comes with 3 year warrenty
cmptrlink: To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this
cmptrlink: is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
cmptrlink: hello
vsurg: I got disconnected
vsurg: how do i get back on?
cmptrlink: hello sir
cmptrlink: are you there?
vsurg: Iam back
vsurg: How do I get back to the live session?
vsurg: I think I figured it out. I am back
vsurg: Please respond. I can't keep this up much longer
vsurg: How do I get back to a live session please?
Posted on Jan 16, 2009
A flashing red light came on my acer projector pd120d but it did not stay on it displayed the power, temp and lamp
Projector bulbs generate alot of heat. Make sure the vents are not blocked or dirty. Check the fan to make sure it is operating properly. Hope this helps.
Jan 06, 2014 | Acer PD120D Multimedia Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Projector shuts down after a couple of minutes with lamp and temp lights flashin, is this a fan poblem and can i replace the fan?
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
May 30, 2010 | Acer PH110 Multimedia Projector
My projector will run for a time between 20 minutes and 2 hours and then it shuts down. It will start right back up (takes 3-5 minutes for it to cool and then restart) after that. What could be wrong?
It could be overheating. Can you hear a fan running? Does the projector feel hot to the touch?
Try putting a small house fan on it to cool it and see if that helps.
Jul 13, 2009 | Casio XJ-360 Multimedia Projector
Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Nov 27, 2008 | Audio Players & Recorders
Aug 25, 2008 | Acer PD120D Multimedia Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Acer PD120D Multimedia Projector Logo
76 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
