Question about Loewe Articos 55 55" Rear Projection Television
I have a loud "whirring" noise whenever the TV is on
Folks tell me that it is probably the "light engine" - any idea where I can even get parts?
    Problem Solver:
  • 15 Answers
In the past the light engine had to be completely changed and Loewe offered a swap out price however Loewe have recently created a procedure for cleaning and refitting the colour wheel within the light engine. Light engine costs around $3200, swap out price around $700 plus labour.
Posted on Jan 04, 2008
Suggest a little more info-like approximate price parts and labor
Posted on Oct 07, 2007
  • 103 Answers
It is actually the color wheel.Thepart an possibly ordered from andrews electrnic supply
Posted on Mar 06, 2007
Whirring noise when car moves
Could be a transmission issue. I would take it to a dealer for assessment.
May 16, 2017 | 2003 Acura 3.2TL
Whirring noise at speed sounds like gearbox
The noise could be a bad alternator or one of the other pulley
drivin parts
Aug 30, 2012 | 2004 Peugeot 307 SW
Loud Whirring Sound from under hood 2007 Mercedes S550
Have the power steering pump checked for excessive noise by a shop locally.
Aug 28, 2012 | 2007 Mercedes-Benz S550 Sedan
My built in lamona oven makes a smell like electicals burning and makes a loud whirring noise when switched on. Any ideas why? have had an electrician in to replace the mechanism inside and the problem is...
This sounds like the magnetron is failing, with a typical smell and a loud noise, there are two additional parts that can be a factor, the high voltage capacitor and diode. To pursue this you will need an appliance repairman or tv technician, the parts and labor will probably run the cost of a new microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Noise when car is started
Sounds like the starter stays "sticked"on... Check the starter relay or after the sound goes away touch the starter for heat. If its too hot it means it stays on working even when the engine is allready running...
Sep 30, 2008 | 1998 Volkswagen Beetle
Installed new bulb and now there is a loud whirring noise and multi colored flashing on screen
Sounds like the same problem I had, I bought a new bulb as well, installed it and nothing. I googled that same issue and endedup buying a kit herehttp://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7that came with capacitors that had to be replace, the kit comes with aservice manual and a bag with lots of different capacitors to replaceany out on your board, they are really good at troubleshooting and theyoffer help online. If that is whats wrong with you, you will need asoldering tool, I bought my as a kit at radio shack for $20.00 and plusthe $36.00 for the kit, and a lot of patience, my TV is well andrunning now, it was better than the $600.00 estimate I got from a localrepair shop. Good luck!
Sep 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Big Screen gets loud, mad and turns off
without a model number, i can't be much help. if this is a newer dlp or similar tv, the fan is probably going out. some newer tv's have a fan that is part of the light assembly, some have a separate fan.. the loud whirring noise is usually caused by bad bearings or the blades of the fan may have become unbalanced, either way, the fan making the noise will need replacing. the color going is usually caused by the lcd or dlp overheating and/or the lamp overheating.
if the tv is out of warranty, remove the back panel, locate the fan making the noise, and search for a replacement. if you have a model number, i can check around and see if i can find the part number for you.
hope this helps,
trin
Nov 19, 2007 | Televison & Video
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Loewe Articos 55 55" Rear Projection Television Logo
196 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
