Whenever I drag the pen across the tablet it brings up a yellow box that it then writes in. I'm trying to use the tablet with photoshop so it's really annoying when I'm trying to retouch a photo and then can't do anything on the screen except scribble on a yellow note-pad. Please help: this was supposed to speed up retouching!
SOURCE: Graphire4 Pen Problem
D< I had that problem, too, so instead i bought a different pen the silver one that goes with the wacom silver tablet ^^ (works perfectly)
SOURCE: Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
SOURCE: Help! Yellow note pad everywhre.
There is a program called Ink - you'll find it in your system preferences under the apple menu. You need to turn it off. This will allow you to use your wacom without that annoying yellow notepad everywhere!!
SOURCE: Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor
from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this
doesn't work after multiple attempts, then the sensor may be too damaged.
SOURCE: Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
