Question about Hoover HF130E Front Load Washer
Hotpoint auarius washing machine door locked
The red door locked light is on permanently. i have read somewhere that it may be the interlocking switch. it said that it may need cleaning? how do i locate the interlocker and remove it for cleaning?
many thanks
karen
    President:
  • 1,462 Answers
I think you have misread - it may be the filter needs cleaning. the door will not open if machine not fully drained and a blocked filter will prevent this.
if machine is not drained then you will get loads of water on floor if you attempt to do filter. get back to me if you want to give it a try - not a difficult job
Posted on Nov 12, 2008
Hotpoint bwm12 door lock light not on, not working!
Try pushing the door in as I suspect the door interlock switch is stuck, if this dosen't work you will have to replace the door interlock switch which can be purchased from Hotpointspares.co.uk and is reasonably easy to fit as can be seen on YouTube .
Oct 24, 2014 | Hotpoint BWM12 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Oct 15, 2008 | Hotpoint WMA13 Front Load Washer
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Door will not open on my auarius extra
I am a recently retired engineer and this sounds like a damaged interlock, its possible that it is faulty and the contacts inside have fused shut, make sure the power is switched off and unplugged for a while and try again first, make sure the cycle has also finished and the machine is empty, etc, to open the door if its still stuck remove the lid and move the clip from behind, you may find that the machine may not work after this, if so replace the interlock with a new one. work safe remove plug, if this has helped please rate me thank you
Sep 11, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hoover HF130E Front Load Washer Logo
77 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
