Question about KDS Radius RAD-5 15 in. Flat Panel LCD Monitor
Problem with color
Only have blue green on monitor
  • 3 Answers
Try unplugging power cord for three seconds. It works for me.
Posted on Feb 16, 2009
5 Suggested Answers
Matampong
  • 153 Answers
SOURCE: 17 crt monitor (BOKA)turned to green resolution
Try moving the VGA cord to the PC, faulty VGA cord displays such color problem.
Posted on Nov 27, 2008
micromend
  • 748 Answers
SOURCE: why is the monitor turn weird color either green or blue not normal color I can see?
Take the monitor back, it's failing.
Posted on Apr 27, 2009
  • 15 Answers
SOURCE: kogi L9CH monitor reddish in color
Sound like the raster circuit is going out. Buy a new one.
Posted on Nov 30, 2009
  • 6 Answers
SOURCE: My Dell E176FP 17
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Posted on Apr 24, 2010
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
My monitor is all weird colors
Generally, this is caused by the loss of one of the main color inputs (Red Green Blue). Do the Following:
  1. Check the cable connections at both the monitor and the computer. Look inside the connector for any bent bent pins (there may be some that appear to be missing, generally that is normal) then reset the connections firmly and tighten the retainer screw snug, but not extremely tight.
  2. If that doesn't resolve, try the monitor on a different system and see if the problem follows the monitor. If it does, try a different cable. If the problem doesn't occur on another system, then the video card of the effected system is suspect.
  3. If issue occurs on multiple systems with known good cables, then the monitor will need replacement.
Dec 21, 2009 | Computers & Internet
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Nov 27, 2008 | Computers & Internet
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
KDS Radius RAD-5 15 in. Flat Panel LCD Monitor Logo
42 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
