Question about Intel D945GNT Motherboard
3 beep sound
How to solve this problem in 3 beep sound coming
    Genius:
  • 1,605 Answers
The 3 beeps means memory problem.
un-install the memories, take a look the stick and the slot. make sure they are in good condition.
reinsert the memory firmly, and make sure they are lock down.
if the still appear, you need to get new memories for the board.
Posted on Nov 12, 2008
04 VW Polo, beeping 3 times,
I am having the same problem. Did you find out how to solve it?
May 27, 2013 | Volkswagen Cars & Trucks
Your question about DG31PR Motherboard has been posted. i have dg31pr M/b,core 2 duo processor,i have 2x2gb ram 667,but long beep sound are coming from,and remove one memory system is working,and put...
Sounds like your second stick of ram is bad or incompatible. I look for a matching stick of ram to the one you have that is working.
Hope this helps
Jan 25, 2012 | Intel DG31PR Motherboard
I have dg31pr M/b,core 2 duo processor,i have 2x2gb ram 667,but long beep sound are coming from,and remove one memory system is working,and put another ram beep sound coming,how to solve this problem?
Sounds like bad or incompatible memory. I would replace the stick giving you issues, try to find a matching memory stick to the one that is working.
Hope this helps
Keeps beeping?
for $19.95 I will tell you how i solved this problem. thanks for nothing fix ya
Jan 17, 2010 | GE Refrigerators
HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
2002 vw sharan 1.9tdi
a vehicle speed sensor will cure your problems and solve your headache they are both linked electrically..
Oct 05, 2008 | 2004 Volkswagen Touareg
Booting problem
One beep is normal during the boot process.
Apr 18, 2008 | Computers & Internet
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
Problem with my newly built pc
Hello!
The information for that specific motherboard lists beep codes for 3 beeps or 4 beeps. 3 beeps signals a memory error, 4 beeps signals a thermal warning.
The PDF is here.
Additional information on beep codes can be found at this site.
Hope this helps! If not, let me know and I will try to find more information.
Jan 19, 2008 | Computers & Internet
Ibm laptop problem
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Dec 27, 2007 | IBM ThinkPad A31 Notebook
Intel D945GNT Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
