Question about Zebra Desktop T402 Printer
Finding configuration file
We have several of these Zebra T402's and we are printing using an ocx file. but we need to change the confiuration of these printers for each user on the PC they are attached to. we want to push this config file to the PC so it does not have to be done manually. were is this file keept on the computer so that we can change it with out using the printing preferences option under properties.
  • jason_baker Nov 12, 2008
    the printer has a config file where you setup the width and length and non contiunus. so basically the printing paramaters. i need to find this file.
  • jrp8 Dec 08, 2008
    My labels feed a little bit more every time-not just 1 label size per feed. The sensors aren't picking up the blank strip between labels. How do I check page length and/or clean the sensor?
    Regards,
    Rud
  • Zebra Master
  • 2,794 Answers
You should be able to put it anywhere on the drive you want to as long as the program you are using to print with can find it and use it.
Posted on Nov 12, 2008
  • Tim Babcock
    Tim Babcock Nov 12, 2008
    Are you using a shiping program like UPS or Fedex with this printer or is this an internal program you are using?
Linux ubuntu9.10 network confiuration
The main network configuration file is /etc/network/interfaces
afeter you edit the network configuration file you should write
sudo /etc/init.d/networking restart
Wait some minutes to the network service to restart and it should be working as per your configuration.
Jul 10, 2010 | ValuSoft Ubuntu Linux for PC, Mac, Linux
LABEL MAKER IS FEEDING PRINTER RIBBON OUT WITH THE LABELS , AND DOESN'T PRINT
there is a some cilindric rubber defective and take ribbon the same time as feeding, you can clean the rubber cylindric with some achool and some soft fabrics (dont touch the print-head)
Dec 22, 2009 | Zebra Desktop T402 Printer
I have TLP 2844 its printing very poor quality
Download zebra setup utility and use it to configure print quality.
Sep 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Zebra 4MPlus printer erroring
check the driver setting USE PRINTER CONFIGURATION
Mar 17, 2009 | Zebra Z4Mplus Label Printer
Zebra T402 USER GUIDE
The T402 has been oblsoleted and Zebra no longer supports the unit.
I do have a copy of the manual in PDF form.
Dec 20, 2008 | Zebra Desktop T402 Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra Desktop T402 Printer Logo
148 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
