Please help me i have no sound or audio on my computer and no little speaker icon int he left bottom corner, i have no disc, the system had to be rebooted witht he disc when my daughter managed to get a virus in it so please please help me get my sound back, i bought speakers but they dont work, my control panerl just says not device found many thanks
what is the make and model of the computer? manufacture TSD, or customized?what is the make and model of the motherboard?
what is the make and model of the audio card?
You can't post conmments that contain an email address.
OK sorry! I get carry away some times.
take a look the computer itself (not the monitor). it should have the model of the machine on it. if you turn the machine around, it should have the manufacture name and the machine model on a sticker.
if you don't find any of these things, then it is a custom build machine, you have to find out who builded. he or she should able to answer my questions.
What type of laptop HP , ASUS , COMPAQ , ACER ?.......... Up the
Volume on My HP Laptop
Open the "Start" menu and click on the
"Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either
"Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the
slider.
If you need to decrease the volume, simply move the slider
bar down.
Click on "OK" when finished and close the
"Control Panel" window.
Click on the speaker icon in the bottom-right corner of the
screen for a faster volume adjustment. Simply move the slider bar up to
increase the volume and move it back down to decrease the volume.
Volume on an Acer
Laptop
Acer laptops are typically sold with
pre-installed Windows operating systems that offer sound-adjustment features
for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem
with external speakers or headphones to increase the volume, as well as mute
all sound on the laptop.
If the computer should output an unusually low volume,
fixing the problem may be no more involved than sliding a control switch with
the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner
to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to
drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control
to open another window with volume controls for "Speakers" and
"Applications," adjusting each slide control upward to increase the
volume.
Be sure the speaker icon below each control is not
accidentally muted.
Click once on each speaker icon to remove the red circle
with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the
lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select
"Adjust Sounds" from the Hardware and Sounds category.
try either right click the speaker icon on the bottom right hand corner of the screen "open volume mixer" click :devices" and select the card you installed. if that fails, go to device manager and disable any other cards the the computer has so it wont conflict. if that fails take it into geeksquad at best buy to see what is going on.
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted hope it helps
First reboot, if you sound has worked before this may help. If not try a different file or you tube video it may be that the file doesnt have sound. Third mke sure your physical button on the laptop is turned up, and Fourth the speaker icon in the bottom right hand corner, if you right click it is it muted? Is it turned down? Get a file or disc that you know has sound on it and that has played before. If this still doesnt work it is a possibility that your audio driver has become corrupt. Try looking for an updated audio driver by using either that manufactures web site or the Microsoft Custom tab when you update windows.
you might have to select stereo speakers in the drop down list if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) hope this helps dont forget to vote
If you are using Windows Vista, or XP: look in the bottom right corner of the screen and you will see a small speaker icon. Click on this. Next you will see a check box for "mute". Ensure this is not checked.
Also, in the search box under the Start File Menu (bottom left corner of screen {windows button} ) go to control panel: make sure that Control Panel Home in the top left corner is slected. If not, select it: then scroll down and click on sounds and hardware. Here you will be able to adjust audio devices, sounds. etc.
After you have made any changes, restart the computer to ensure the changes are made, and test the speakers.
Please let me know if you need further assistance.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
Goto Control Panel
Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
In device Volume Click Advance
Master Volume Control Window will open
Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
Have you tried a plug in headset mic ? Right click the little speaker icon in the bottom right corner of your screen.Left click Adjust audio properties and go from there.
Looks like your audio drivers have gone. have you tried system restore? Go to start, all programs, system tools system restore, then choose a previous date when your sound was still ok.
If you are running windows,go to the bottom right-hand corner where the clock is and click on the little red arrow. A little row of icons pops out-there should be a little picture of a speaker, left click it and make sure the slider is all the way to the top and that the mute check-box is not selected. If that dosent help go to Start-Control Panel-Sounds Speech and Audio Devices-Sounds and Audio Devices and make sure that the Mute option isnt selected in the Volume or Audio Tabs. Also make sure that the volume slider are at maximum and that you click 'apply' for the changes to be applied.
Okay im just a normal house wife where do i get that information?
