Sharper Image Ionic Breeze 3.0 Air Purifier
Problem for Sharper Image Ionic Breeze 3.0 Air Purifier
Ionic breeze 3.0 repair
By hocker on Nov 12, 2006
My ionic breeze 3.0 stopped working the other day. I have cleaned it and still it does not get any power at all. Tried all kinds of outlets. Is there any solution out there for me without sending it out for repair? Should I buy a new one? This one is only about 9 months old. Please Help!!!
Same Problem
Aug 30, 2008
-   Same problem...no wonder the Sharper Image went bankrupt...I even have the replacement guarantee...but what can be done now? -   drmary847
Aug 26, 2008
-   NO MATTER HOW MUCH I CLEAN IT, THE UNIT WILL NOT COME ON; whgick@email.com -   Guest
Aug 26, 2008
Aug 26, 2008
Aug 26, 2008
Best Solution
posted on Aug 02, 2008
Very Helpful)
martinmarty
Rank: Master
Rating: 93%, 11 votes
My Ionic Breeze GP began losing power occasionally but I could shake it and get it to turn back on. It got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not to be recommended, but I consider the sacrificing the switch for the back cover to be introducing only limited risk, so I might take that route if I have to.
Comments:
Aug 09, 2008
- This is a follow-up to my August 2, 2008 post.
I found a suitable replacement switch at Mouser Electronics, mouser.com. It is Mouser part # 101-1203-EV. The problem is that the lever is too long, so I cut it with my Dremel cutting wheel before installing.
Mouser also has a similar switch, part # 101-1201-EV on which the lever is the correct length, however it has solder lugs instead of PC board legs.
I ordered both switches and then made my decision about which to use after looking at them. The choices are either cut (shorten) the lever on the 1203 switch or enlarge the holes on the mounting board to fit the 1201 switch. In my judgement it was easier to cut the lever.
The new switch is installed and the unit is working fine again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 10, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The rear grill has an electrical contact on it. If the grill is not seated properly, electrical contact is lost and the unit will not run.
Here's how to remove and reseat the rear grill:
1. Turn off the unit.
2. Unplug the unit.
3. Remove the collection grid.
4. At the bottom of the rear grill is a blue tab. Pull it toward you and lift the grill up and off.
6. Put the grill back on so that the locking tabs go into their slots.
5. Slide the grill down to lock the tabs in place. Verify the blue tab is latched.
6. Put the collection grid back in.
7. Plug the unit back in and turn it On.
If that doesn't work, it is possible the contact in the rear grill is still not touching correctly. Use the steps above to remove the rear grill. Then locate the metal strip on the inside lower portion of the grill. Clean it and clean the metal pin it is supposed to touch on the chassis. If the contact is tarnished, use an emery board to shine it up. Also shine up the pin. Then VERY gently lift the contact a little so that is sticks out further. Replace the rear grill. Insert the collection grid. Turn the unit On.
Solution #3
posted on Nov 05, 2007
Somewhat Helpful)
tetherton
Rank: Apprentice
Rating: 79%, 5 votes
The unit will not power on if the grills are not attached correctly. Pull on them to see if one of the sides did not seat right. The grills can appear to be fully attached even when they aren't.
Was this helpful?
Yes
No
Solution #4
posted on Apr 12, 2007
Somewhat Helpful)
tlr1000
Rank: Apprentice
Rating: 79%, 4 votes
Sharper Image will replace it if you call them. Unfortunately, most all of them end up with this problem at some point.
We are on our third one and its been relegated to the dogs room.
Was this helpful?
Yes
No
Solution #5
posted on Mar 30, 2009
Not Rated)
valsigplym
Rank: Apprentice
Rating: 100%, 1 votes
I fixed it! I cleaned the contacts mention previous PLUS around the wires and beads at the bottom. It works again. The front grill comes off and gives ample access to the beads and contacts. I also blew the whole thing out with compressed air. Good Luck!
Was this helpful?
Yes
No
Solution #6
posted on Sep 06, 2008
Not Rated)
tkcordato
Rank: Apprentice
Rating: 0%, 0 votes
If you purchased the replacement and service guarantee you will receive your money back from NEW ( the warranty company) The info is on the Sharper Image Web page. My unit quit and I received a check for the full amount very quickly last month.
Was this helpful?
Yes
No
Solution #7
posted on Aug 23, 2008
Not Rated)
gadamslee
Rank: Apprentice
Rating: 0%, 0 votes
can you give me the number to call to get it fixed thank you all :)
Was this helpful?
Yes
No
Solution #8
posted on Jul 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
cleaning contacts and reseating did not work
Solution #9
posted on May 21, 2008
Not Rated)
Schizy
Rank: Apprentice
Rating: 0%, 0 votes
I thought I read that the Sharper Imaage went out of business. Their supposed web site now looks sort of ametuerish and crude. What's happenin'?
I'll take that as the warranties all died.
Was this helpful?
Yes
No
Solution #10
posted on Dec 22, 2007
Not Rated)
starfixer
Rank: Master
Rating: 87%, 26 votes
return it under warranty why go through the hassele of trying to fix it will only be out for about 2-4 weeks.
Was this helpful?
Yes
No
Popular Solutions for Sharper Image Ionic Breeze 3.0
Questions and Unsolved Problems for Sharper Image Ionic Breeze 3.0
Do you recommend Sharper Image Ionic Breeze 3.0 Air Purifier?
Answer
Answer
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the... (More)
Answer
our ionic breeze air cleaner is about 5 years old. For the last few months it has been giving off a... (More)
Answer
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and... (More)
7 Other Users Have The Same Problem - Continued
Comment by wrkrbee, posted on Jun 20, 2008
I have the ionic breeze quadra with the ozone protector on it. Just last week mine quit working. Doesn't get any power to it at all. Also to note, although it would never notify me when it needed to be cleaned, i cleaned it every couple of weeks because I have two large dogs.
I followed the instructions in the other post but did not see any blue contacts. I disassembled my unit and cleaned the entire inside, cleaned the pins on the bottom inside of the unit with electrical cleaner and even roughed them up with a scotch bright pad.
While I had it apart i examined the board which is located underneath in the base as best i could without removing those portions and nothing appeared to be melted.
I also examined the circuitry on the top board which is attached to the power button and nothing appeared melted - but that one did seem older.
Comment by Twon10g, posted on Apr 28, 2008
I have the same problem! It jsut quit working. Will not power on at all.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharper Image Ionic Breeze 3.0...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2519
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
