I have a D-Link DI-624 Wireless Router. My Comcast cable high speed does work but none of the wireless laptops are seeing the network. I've unplugged it etc but it still doesn't come up.
    Scholar:
  • 69 Answers
There are a few configuration problems that can cause this. lets start with the basics. I will assume two things for this process.
a- that you will be right next to the router with a wireless laptop/computer so we can rule out transmission interference
b- that the laptop/pc that you use has connected to a wireless network before.
Problem #1
the router is not setup to send a wireless signal.
SOLUTION: run the setup wizard and make sure that the wireless options are turned on. If you would like help with getting into the wizard you can consult your manual and if needed i can find out how for you. Its usually a program that is installed or you can connect to your router through your browser for the configuration interface.
Problem #2
the router is transmitting a wireless signal but not the name of the signal (its called the "SSID")
SOLUTION: the same as above you must get access to the settings and make sure that there is a name in the SSID space and that it is transmitting said name.
just starting with the basics like i said we can work our way up if you still need assistance i will help.
Posted on Nov 12, 2008
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hello i have dlink router 624 and 2 pc and 2 laptop sudenly one pc stop connected and signed that cable unpulg ....network connection with other pc and wireless laptop is excelent. when i exechange...
Check the plug of network wire going into PC - OR Replace the wire completely. Maybe blow out any dust from the socket. It may work if you just wiggle the plug in the socket.
If none of that changes anythig, then you may need to replace the network card in the pc.
If it's built in to the mother board, you can disable it in BIOS, and install a new one.
Dec 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link connect to comcast
connect the the ethernet cable to the WAN port of the modem.
the connection should be:
One end of the cable is connected to the modem and the other should be connected at the WAN port of the modem.
Now use another Ethernet cable plug it in on the LAN port1 and the other end to your computer.
Access the configuration page of your router and set the wireless setting inside your DI-624 router.
Dec 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
WIreless card not connecting
Go to the device manager on your computer(one with wireless card) and install the wireless card with all of its drivers. Then try to connect.
Apr 03, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
