Question about Cameras
Camera will not power on!, Worked fine rechargeable batteries went dead, replaced them with CRV3 lithium, no power, triedregular heavy duty , nothing.
    Champion:
  • 225 Answers
Then the camera system board is dead. It happens a lot.
Posted on Nov 13, 2008
I have this camera and it has new batters but it wont turn on.... WHAT DO I DO
The CRV3 lithium battery, is non rechargable. It must be lithium, because lithium has a higher voltage than other batteries.
Not sure if you can put the batteries the wrong way around in the camera but be sure you did put them in correct. Check if the contacts in the camera are clean and shiny.
Nov 02, 2013 | Kodak EasyShare DX6340 Zoom Digital Camera
My Kodak ZD710 Will only let me take about 11 pics and the batteries go dead, I have used the CRV3 battery pack
Welcome to FixYa.
Kodak lithium digital camera battery CRV3 (non-rechargable) approximately can take pictures up to 500 pictures. However, actual life may vary based on the usage.
How to extend your battery life?
1. Use power saving features (using a power saving modes). Limit activites such as reviewing pictures/videos on the LCD.
2. Dirt on the battery contacts can affect battery life. Wipe the contacts with clean,dry cloth before loading the battery in the camera.
3. Battery performance is reduced at temperatures below 41 F(5 degree celcius). When using your camera in cold weather, keep spare batteries warm. Do not discard cold batteries; when they return to room temperature, they may be usable.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 14, 2011 | Kodak EasyShare ZD710 Digital Camera
Camera powers on, then powers off
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak EasyShare Z710 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
Aug 23, 2009 | Kodak EasyShare One Digital Camera
Batteries die within a few minutes
you may have a short or you've uped the settings to max. (like lighting of screen.)
Aug 23, 2009 | Polaroid i835 Digital Camera
Kodak EasyShare z812is Battery issue
Try using the Kodak CRV3 lithium battery, I will cost you, but the battery works. The z812is is to powerful for any rechargeable battery.
Jun 03, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Battery problem
For my Z712 I'm using since one year CRV3 li-ion rechargeable.
No problems until now, few THOUSANDS of photos.
I've buy it from ebay.co.uk .
Regards.
Oct 06, 2008 | Kodak EasyShare Z712 Digital Camera
EasyShare Z712IS
the camera will work with any brand of lithium but only the KLIC 8000 battery will work as a rechargeable
please look at your getting started guide and check page 1, there's an illustration of the 3 types of batts that will work:
lithium crv3, lithium aa and klic 8000
ni-mh is really not compatible
please check at the bottom of your camera, the three types of batts I mentioned are engraved at the battery door
thank you
Dec 31, 2007 | Kodak EasyShare Z612 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
