Question about Dryers
Kenmore 600 Series Dryer
How do I open the top of the dryer so I can clean the lint inside?
    Scholar:
  • 66 Answers
What is the model#?
Posted on Nov 12, 2008
Kenmore 90 series electric dryer qiuet pak 1 101649022200 the lights are on when you open the dryer but the dryer itself will not turn on or do anything!
There's thermal fuse on the blower that blows when the cycling thermostat malfunctions or the lint/vent duct are blocked. This thermal fuse is wired in series with the dryer motor and if it blows, power to the motor is terminated causing the dryer not to start and no dryer function works. Check to make sure that the lint filter is always clean and the vents are clear. Click on the link below for the detailed troubleshooting of the dryer, particularly the thermal fuse, when it doesn't start.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 09, 2011 | Dryers
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
Have Kenmore 90 series elec. dryer...will start, but then cuts off and doesn't dry clothes. Trying to clean the lint out of it. We've taken all the screws out of the back, but can't get the back off!...
Hi-I just cleaned out mine. You take off the clamp that holds the exhaust duct from the bottom of the back of the dryer and you will be able to vacuum it out. Then you can remove the kickplate on the front of the dryer by lifting it hard and pull the top of it out. Then you can remove the lint trap holder once inside by unscrewing it, remove it and clean it out(take out the lint filter first). I vacuumed out the inside of the exposed bottom gently cause it was so full lint! Hope this helps!
Jan 23, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Help getting kenmore dryer apart
remove the two top lint screen screws,pull the top toward you and up,remove the two front panel screws one on each side top,disconnect the door switch,pull up and out and your in the dryer,let me know if you need more help-mike
May 27, 2009 | Dryers
How to i open a kenore dryer to clean it
is your lint screen on top or inside?mike
Feb 14, 2009 | Kenmore 65924 Electric Dryer
Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Dryers Logo
899 people viewed this question
Top Dryers Experts
