Question about Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
Lost prime I was putting a pool cover in my pool and it blocked the intake filter for just a few seconds and now the filter is not pumping water what do I do?
  • 4 Answers
Turn off the pump at the timer and remove the lid to your pump where you empty the debris from the basket. Get a hose or bucket and fill that resevoir with water and get the lid back on as quickly as possible. Turn on the pump and it should start to prime. On the filter, there is a air relief valve. Depending on the filter, it will pinch and twist, or there is a knob to uncrew. Doing that as the motor is running allows tbhe air that has built up inside to puge out. Once a steady stream comes out close the relief valve. May need to tryh it more than once.
Posted on Dec 07, 2008
My swimming pool pump is loosing it's prime
is there enough water in pool sometimes skimmers suck air also check the intake union of the pump you have a leak in one of your intake lines
Jul 12, 2014 | Pool & Spa
Error after short prime cycle
Apr 21, 2014 | Pentair IntelliFlo VF High Performance 3HP...
Has no suction
The intake, filter, or impeller may be blocked. Make sure the filters are clean, and intake pipe has nothing jammed in it. Also when trying to get it going, make sure the pump is well primed, which means the intake water level must be as high as possible, and the skimmer box and intake filter basket must be full of water.
Aug 29, 2013 | Pool & Spa
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
My intex pool pump is surging and won't stay primed???
i think its pump side first as its easier to push water through a filter rarther than trying to **** it , Also the only reason it could loose its prime is through air getting in the system.
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Lost my prime in my pump, i have tried numerouse time fill the basket area with water turn on pool pump nothing, any more suggestions. I lost my prime to my pump a few weeks ago . I had a pool company...
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Apr 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Logo
396 people viewed this question
Top Intex Pool & Spa Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
