Question about PNY Optima 1GB PC2-5300 DDR2 SoDIMM Notebook Memory
Need to install memory
I purchased PNY 1bg DDR2 PC2 5300 and need to install it on my gateway tower. Do you have instructions anywhere I can download?
    President:
  • 1,901 Answers
It's fairly simple.
How about a short video from youtube?
Here are a couple links:
http://www.youtube.com/watch?v=SiFIgSQOY7g
http://www.youtube.com/watch?v=yrooMIuj3iE&NR=1
A couple things to remember:
Remove power.
Ground yourself on the computer case.
Make sure the notche(s) line up.
Posted on Nov 12, 2008
Its a pny adapter i need to know where to place it in my 760 optiplex dell tower
You need a SD card adapter to insert a MicroSD card and be able to use it
Oct 17, 2015 | PNY 2GB microSD Memory Card
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
I need the fan size and voltage for a PNY 8500 GT so I can buy a replacement, but it doesn't seem to be listed anywhere
you have to find out which producer of cooling you want,fx Zalman ,northQ....
Than you have to look on there homepage for a list of compatible produkt list for your card.
Almost any gfx cooling producer makes a model for the 8800gt.
I prefer zalman....they looks great and easy to install.
http://www.youtube.com/watch?v=sFoS4SE1kxg
Jun 02, 2010 | PNY Verto GeForce 8500 GT 512MB DDR2 PCI...
Gateway computer LX series need to recycle power before it will go into post.
The only reason I can see in a no POST issue is because of a defective hardware in your computer.
1. Try to remove all the cables at the back of your computer tower and power cycle it for 15 seconds.
2. Plug the power cord back in and the monitor cable only then start your computer.
3. Put the devices one-by-one to your computer tower until you see the faulty device.
4. If no faulty device detected after connecting all the connection at the back of your computer tower.
5. Try to open up your computer tower and reseat your Video card, memory, HD cables and CPU as well.
Let's investigate if the problem will reoccur.
Jan 01, 2010 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
How to install memory upgrades on GATEWAY GT 5042B PC
CLICK HERE. to get all the information you need about your computer.
Memory:-
  • Installed: 512 MB DDR2 533 MHz (PC4200) SDRAM
  • Expandable to: 4 GB (4 DDR2 slots)
  • If you want to know how do i install it? CLICK HERE.
    please rate my solution very high, if this infornmation is helpful.
    Sep 23, 2009 | Generic Memory Computers & Internet
    I replaced a 512mb memory for the pny 2x1GB ddr2 pc2-5300 to improve my system performance but when i turn it on my system shut down a while after i had log in to my account then i removed the memory card...
    You may have a bad memory stick. If the two are not exactly the same spec they may not be compatible.
    Haev you checked that your motherboard is capable of handling 2gb of memory? And that it is the correct type of memory(size and speed) and that you are placing it in the correct slots(ddr2 only goes in ddr2 slots and ddr only works in ddr)
    The power supply makes no real difference to memory, replacing that is not a solution
    Jul 26, 2009 | PNY Optima 2-Pack 1GB PC2-5300 DDR2 DIMM...
    Windows xp sp3 maximum amount of memory
    HI,
    Of course it can be done, your computer can take up to 2BG of ram (memory) and the slots are located inside the computer tower like this >>>>>
    Your motherboard will have 2 slots like in the picture and will take 2 x 1BG (1GB in each slot), just make sure you buy the correct speed and type memory so it's a good idea to take your memory with you when you buy is so there is no mistakes.
    Good luck
    Jun 19, 2009 | E-Machines eMachines Desktop PC
    PNY Does not Honor ''Lifetime Warranty'' for memory
    SAME HERE
    Ram installed about 2 years ago I think 2x4gb ddr3 sodimms
    Failing after a year started as blue screens and not recognized short time after.
    Without receipt = no warranty
    Got it as a gift = no warranty
    Oem = no warranty
    Purchase with gift card and misplace receipt = no warranty
    House burn down with all paperwork = no warranty
    Not good at keeping records =- no warranty
    I have been in contact with PNY and can you tell they have told me without the receipt they can do nothing for me?
    COMPLETE WAISTE of the word warranty.
    and yes there support people get smart with you and quote other companies warranties and state see they do they same thing!
    WAY TO STAND OUT!
    Why even have a lifetime warranty, just call it a "prove it" warranty?
    Dec 07, 2008 | PNY Optima 1GB PC2-5300 DDR2 SoDIMM...
    Installing memory
    u sure it aint bad video card proably wrong ram type dual ch or no ? need help email me drummernick2002@aol.com live help thx nick
    Jun 06, 2008 | Acer Aspire™ T180 PC Desktop
    PNY memory
    Hi
    Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
    From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
    Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
    The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
    To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
    Let me know if further help is needed.
    Mike
    Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    PNY Optima 1GB PC2-5300 DDR2 SoDIMM Notebook Memory Logo
    Top PNY Computers & Internet Experts
    David
    David
    Alun Cox
    Jim Thurston
    Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
