Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KV34HS510 Picture will not come on. I can hear the power trying to switch on, but then seems to switch itself off, so no picture. Yesterday, the standby light blinked a series of 6. Today, it seems to be blinking a series of 5. This is our only TV. If you can get it to turn on we will never turn it off again until we get a new one. Help!
  • 3jjjess Dec 02, 2008
    Once I turned the TV power off it stays off and when I turn it on remotely or manually it seems as if it wants to turn on but it shuts off by itself and the standby button stays on. what can I do? I have unplugged the TV from the surge protector and connect it straight to the plug and it did the same, left it unplugged all day and tried again and it still does not turn on.
  • kcizzle Jan 08, 2009
    Sony KV34HS510
  • 40 Answers
This could be a malfunction of the internal power supply.please contact the nearest repair shop without plug it in again.
Posted on Nov 13, 2008
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
Sep 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
NO PICTURE/RED LIGHT KEEPS FLASHING/SOMETIMES PICTURE COMES ON AFTER NOT PLUGGED IN TO POWER
My KV34HS510 Led flashed 4 times then stops for a few seconds and repeats. Is this the D Board MCZ3001D IC problem?
Feb 02, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Mar 25, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Sony WEGA KV34HS510 Clicks when turned on, but get no picture and the standby light flashes.
A 3 flash shutdown indicates a low voltage condition in the power supply (the D board) If you have electronic experience, I can walk you through some things to check. Otherwise, it's time to call a technician
Nov 18, 2008 | Televison & Video
PS3 no picture and no sound
Try turning the system off completely with the main power switch on the back of the console. If that doesnt work call Sony technical support for further help.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Sony kp-s4613/2
Sir,
We have solve this problem by resoldering the power supply and vertical section.In few cases we have seen mains filter capacitor in power supply also defective.
Oct 24, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
322 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
