I do not know how to put in videos onto my mp3 player, I put it in but on the mp3 player it says its empty. do you know how to fix it?
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-http://www.fixya.com/support/r5874192-play_videos_mp3_player
SOURCE: how do i put music onto my mp3 video player
To do this you will need the software that came along with the player.
Like for Ipod you get itunes.
Install that software & plug the player when you are prompted.
Then it will detect the player.
And then select the tracks which you want to transfer to your player.
It will be done.
Mp3 rocket is a software to download the music.
I've never used mp3 rocket to transfer before but if you have all your songs in a folder you can go to itunes and click on File and add folder to library.
Then you look for the folder with all your mp3 files and click on it and select OK.
Hope it helps.
If you want the instructions in sing the itunes i can give.
Just ask me.
Good Luck.
Live, Love, Laugh.
SOURCE: help regarding downloading videos onto my mp3 player phillips
drag your media files in to the correct folder in you mp3 player's folder which can be found in My Computer.
or download a converter thingie.
SOURCE: How to put videos on my sony nwz-s615f
Go find the icon of the MP4 you want to put in your MP3, then copy it, then go on 'My computer', find the icon of the MP3, click on it, and there should be a folder called 'VIDEOS' click on it and paste the video you just copied.
* The video must be MP4
SOURCE: can't put music on my mp3 player
First of all, go to a site where you can download mp3s, like 4shared.com or Limewire.com. However, it's recommended that you purchase them safely and legally, like on iTunes or Wal-mart Music downloads. Save the file and download it to a folder on your computer. The mp3 will take a while to download but when it's finished, you can open it with a music program on your computer, like Windows Media Player or iTunes and listen to it. Make sure your mp3 player is plugged in and it shows up as a device on your "My Computer" and that it shows up on your music program. You can most likely drag the mp3 from the program to your mp3 player. Hope that clears everything up! If not, just comment me.
~Elle
SOURCE: Icant put videos on ematic mp3 player?
What you need to do is have your videos set to be converted by the MTV convertor that came with the device. It's usually on a mini disk.
You have to download the software and then input the video you want to convert.
The thing is that not any video will be recognized by the software. You'll need to convert most stuff to .avi files first.
For example, if you download a non-copy righted clip from youtube, you have to convert that to .flv format. (I recommend keepvid.com) Then you need to run that that to an .avi format. For that I would use MediaEncoder from sourceforge.
