Question about HP LaseJet 4350dtn Laser Printer
Why does my printer 4350 always goes into a sleep mode?
Can I turn it off?
4 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: 4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
Posted on Jun 19, 2010
  • 48 Answers
SOURCE: Brother HL-2170W laser printer goes
Try to press Setup Menu then find Sleep and turn off
Posted on Nov 03, 2010
  • 8 Answers
SOURCE: Printer goes into sleep mode and does not come out
As far as i know it is a formatter problem. Did you test it with another formatter?
Posted on Jan 10, 2012
Turn sleep mode off
Go to Settings. Tap on Display, then tap on Sleep. Select a screen timeout duration.
Jul 26, 2014 | HTC Desire Cell Phone
Printer not responding hp photosmart 6525 after going into sleep mode
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Nov 30, 2013 | Office Equipment & Supplies
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
Power save mode sleep
Hi Brian,
The printer goes to sleep mode irrespective of what cartridge you have in the printer. Printer goes to sleep mode if the printer is not in use.
Regards,
Sean
Jun 04, 2013 | HP LaserJet 5500 Printer
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Jun 19, 2010 | HP LaserJet 4350 Printer
Mar 25, 2009 | HP LaserJet 3600n Printer
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
HP LaseJet 4350dtn Laser Printer Logo
132 people viewed this question
Ben Johnson
