Question about Lands Phones
KX-T7435 How do you set the time?
Set up answering system
Follow the instructions beginning on page 57 of the manual at ftp://ftp.panasonic.com/telephone/om/kx-tg7622_mul_om.pdf
May 26, 2016 | Panasonic KX-TG7622B DECT 6.0 Plus...
Change time
Press "OK" button.
Scroll down to "Settings", (May be handset settings.)
Go Right on scroll button.
Scroll to "Date & Time settings"
Enter date and time.
Nov 03, 2013 | Panasonic KX TC1881B Cordless Phone...
HOW TO SET THE TIME KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 14, 2010 | Panasonic KX-T7630 Corded Phone
How to set time on Panasonic KX-T7633
From the system administrator's phone, enter programming and dial 000 and follow the prompts using the FWD and CONF button to move the cursor back and forth.
Carl
Aug 21, 2009 | Panasonic KX-T7633 Corded Phone
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
May 19, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Carnt change the time on my phone
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
Kx-t7435
Your phones are connected to a Panasonic phone system. The system does not look like a phone at all. Each of your phones has it's own set of wires going to the brain. The system is what holds all the programming, you could have one of many different systems and they all program differently. So, first you need to find out which system it is. Most likely the part number starts with KX-T..... just like your phones but it's not guaranteed.
Some systems do need to be programmed from the operators extension (typically the lowest number extension on your system)
Dec 04, 2007 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
