I adjust my convergence but i still cant get it perfect, I play my xbox 360 on the tv, or movies etc,,,,the letters when small are blurry and you can see the red or blue coming from the white, not alot but enough to piss me off...I have had this tv for several years..Any suggestions...
Remove the back containing the mirror and look into the projection lenses either at low brightness or with the tv turned off using a flashlight. Look for the fluid posibly being murky (should be clear). If this is the case, to replace the fluid:
1. Unplug the TV.
2. Remove the Picture Tube with Lens Assembly that has bad fluid 3. Find the drain plug
4. Drain the fluid in the sink. 5. Take a picture from all angles to review later. 6. Dissassemble the fluid chamber from the picture tube and clean the front glass and chamber. 7. Reassemble and fill chamber with mineral oil (laxitive found in a drug store). 8. Repeat the proceedure until all three CRT images are clear. 9. Use the centering magnets located above the CRT PCB's to get the convergence in the center. 10. Use the convergence proceedure from the tv menu to complete.
sonof... indicated that his solution for Grand WEGA... Problem is valid for all Projection...
There is a certain level of tolerance for misconvergence - it is extremely hard to get a set perfectly aligned. If you go into an electonics store you will often see the same thing - very slight misconvergence on small white text. You might could try getting the set re-aligned by a professional, or if its really bad you may need the convergence chips replaced, but it sounds like your set is normal.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I replaced the missing silver box on the new board and I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
dont ever change the fluid in the tubes just clean all the optics and lenses mirrors go easy on the screen reset up the focus block screen and focus adjustments your xbox has way more resolution than the old tosh is capable of have somebody do the service converge for you
I have a Grundig TV, It works for few secs, when I switch on & goes to stand by mode. After...
(More)
I have a Grundig TV, It works for few secs, when I switch on & goes to stand by mode. After few tries it works fine. What could be the reason? I watching TV programs using DSL line- using a media receiver.
my tv wont come on at all the power indicator light just blinks and nuthing else at first it sounds...
(More)
my tv wont come on at all the power indicator light just blinks and nuthing else at first it sounds like it want to come on but it dont do anything please someone help me im broke and need to fix it cheepo
Toshiba 43H70 - worked fine yesterday. Today, no picture. I can play a DVD and hear it, but no...
(More)
Toshiba 43H70 - worked fine yesterday. Today, no picture. I can play a DVD and hear it, but no picture. Can't get any picture when using the cable box for tv. Is it the lamp that is out?
