The TV was made in October 2004. I have looked at the capacitors, I don't see anything that looks wrong but I know nothing about tv repair. None of them are swollen up.
If set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
SOURCE: Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
