Question about Dell 3100cn Laser Printer
Dell 3100 CN printer...message on printer reads load tray
There is paper in both trays. Have tried restarting, unplugging, pulling out the bottom tray and printing to the MPF tray only and then vice versa printing to the A4/Tray 1 and nothing works.
  • mkimbl Nov 12, 2008
    The error message is reading Letter and goes back and forth to 024-964
  • Damanpreet Chand
    Damanpreet Chand May 11, 2010
    Please tell me the exact error message or error code number or blinking lights on the printer.....Only then I could tell you where is the issue exactly......
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size button.
  4. Press the down arrow untilDell 3100 CN printer...message on printer reads lo - return%20arrow%203100cn.jpgb>Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg butDell 3100 CN printer...message on printer reads lo - return%20arrow%203100cn.jpgh_mi">Press the down arrow to select the specific paper size, as shown in Figure 1, and pressDell 3100 CN printer...message on printer reads lo - 43d7cbe.gifrc="http://i.fixya.net/uploads/images/return%20arrow%203100cn.jpg" alt="return%20arrow%203100cn.jpg" class="h_mi" /> button.
  5. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the tyDell 3100 CN printer...message on printer reads lo - return%20arrow%203100cn.jpgrator panel, perform the following steps:
  2. Press the down aDell 3100 CN printer...message on printer reads lo - return%20arrow%203100cn.jpg appears and press the return%20arrow%203100cn.jpg button.
  3. Press the downDell 3100 CN printer...message on printer reads lo - return%20arrow%203100cn.jpg/b> appears and press the return%20arrow%203100cn.jpg button.
  4. Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Posted on Nov 12, 2008
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Dell 3110 cn has full paper tray but keeps giving the following error code " Load Tray 1 0240965- A4" . I have taken the paper out twice and reloaded it. I also tried turning the printer off for...
The paper may not be 'lifting' as you push the paper tray in.
Open the front 'door' of the printer, remove the toners, so that you get a clear view of the paper tray. Is the paper in contact with the pickup rollers ?
The paper tray lift mechanism can wear and there is a small plastic component that can break. Replacing the paper tray will probably do the trick and fixe this.
Jan 28, 2011 | Dell 3110cn Laser Printer
I have a dell 926 series printer lost the booklet how do i load the paper
You posting shows a Dell 3100cn printer (laser), but you say it's a 926 (inkjet). If a 3100, pull the bottom paper cassette tray out and load the paper. Make sure the sttigs for the paper are correct, e.g. "Letter". If it's a 926, the paper goes in vertically at the top rear of the printer.
Apr 25, 2010 | Dell 3100cn Laser Printer
The printer message says: load paper tray and it is already load
Something to try, The paper (roller) may be slipping on the paper giving false reading of Load paper tray. UNPLUG THE PRINTER FROM MAINS and CLEAN the (roller) as best you can with quick drying solution, Tape cleaner or Similar. Good luck Bob.
Mar 18, 2009 | Dell 3100cn Laser Printer
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
Dell printer 3100 cn laser
I had the dreaded 024-969 and was just able to print a test page.
I removed paper and reached inside the MPF. There's a spring-loaded lever facing upward, toward the back of the tray that the paper rests on and depresses. I toggled this up and down a dozen times.
I vacuumed out the entire tray area and then blew air into the same area by reversing the shop vac hose connection to the output hole.
Printer now prints.
Jun 11, 2008 | Dell 3100cn Laser Printer
Load tray message
It may not be the size settings, it may be that you need to reinstall the driver software. The Best thing to do first is unhook the pritner from the computer and uninstall the printers software. Once it's uninstalled, Reboot the computer. then Reinstall the Software, inserting the pritner cable when advised to, this usually resolves the issue, If it doesnt, then there is eithe a firmware or a sensor or feeder failure. Those are best to be troubleshooted by Dell themselves.
Nov 29, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
6,160 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
